I tested x64 "appplayer" build with my mixed smartplaylist. I use two different sorts on it to produce a pseudo-random ordering of songs / mvs. I start the playlist by using the <p>lay action on it in the music window. I verify the loading of items by viewing the musicplaylist window. I played each playlist to a depth of 12 items. Both played correctly. At this point, the problem that I could see in 180106 x86 builds and later is RESOLVED. I will do some freeplay in case there are other side effects. I did do a quick testing of song and mv party mode and that is working as expected.
scott s.
Thanks for test feedback and Fernet/Fritsch for the fixs. I'll remove this from the Beta known faults list.
Tested all scenarios again with this build KodiSetup-20181008-06ac6db9-master-x64.exe
No issues, switching between players works flawlessly.
So thanks to everyone involved in the fix
docwra
Posting Freak
Great work all, thanks to the developers!
