it seems to work on SHIELD.
First I tried it with the XBox controller and it worked right away.
Then I tried the Shield Controller and did not succeed.
A while later, I started Kodi with the SHIELD controller (Xbox controller in standby) and now it worked with the SHIELD controller, but now no longer with the Xbox controller.
garbear
Team-Kodi Developer
Kodi should assign the controllers in order of last button pressed. may analog sticks are messing this up, if Kodi is seeing them as always pressed . can you try to see if buttons vs analog sticks make a difference?
garbear
Team-Kodi Developer
The PR that fixes the joystick order can have the side effect of shuffling all player numbers when a controller is connected/disconnected, so maybe we should use OS order but just sort the in-use controllers before the not-in-use ones. I'll think about this an open a PR later.
2018-11-29, 16:58
(This post was last modified: 2018-11-29, 16:58 by NxtGenCowboy.)
I installed that latest test build and I had to reprogram the "kodi" controller that is listed(which is the nvidia shield controller) Otherwise the controller didn't work at all. Once I did that, I was able to play most games using the dpad, not the joystick. Seems like the mappings get lost for some reason. However, this was NOT a fresh install so something else could have cause it.
xbmc17
Senior Member
Sigh, tried latest build after a long break, Shield controller doesn't work, buttons are messed. Why on earth is it so difficult for Kodi to ever work properly on such a popular device? Bought MRMC, everything works immediately. Jodi's development is also so inconsistent and frustrating.
