That's because its trying to install the android package on windows. It doesn't contain the library for windows so it can't load it. Let me ask how this could happen.
2020-10-10, 22:21
(This post was last modified: 2020-10-10, 22:22 by phunkyfish.)
Looks like there is an issue with the repo. I can create you a test build to install manually tomorrow.
When i configure enigma2 addon on kodi i get always a error no channels found. I have a Vu+ Solo 4K.
Can you post a full debug log? Instructions in my signature if you don’t know how.
I've used the addon for some time now with great success.
For some days/weeks I'm getting error messages that the connection to the server is lost. It takes some time and the connection is up again. During this messages I do see at my VU+-box that there is a heavy load (is it called 'spinner'? - don't know).
My setup is as follows:
- VU+ ultimo with OpenATV 6.4 (latest)
- Intel NUC with libreelec (dev-/test-releases - matrix)
- the pvr-add-on is the latest that is to get with libreelec.
Is there someone who is experiencing the same? Is there a setup that I have to correct?
Kind regards,
Tom
You will still need to restart your enigma device probably once a week but it’s been ok like that for me for the last for weeks.
2020-12-13, 16:55
(This post was last modified: 2020-12-13, 16:55 by phunkyfish.)
You only see the extension because there is no movie data associated with the video file on your STB. This file I assume was just copied to the device instead of being recorded. So the answer is that it has an extension because it’s not a recording made by your device.
