Weird question about the Odroid N2...
Turns out the 4 little feet are spring loaded. I know this because one of the 4 feet on one of my 6 N2's has 'popped'. I can push it back in and it seems to lock but a few minutes later it will 'Pop' again.
It drew my attention to those little feet anyway. The feet in the locked position are above the level of the tall side heatsink fins. ie. all my N2's rest on the side fins not on the 4 little feet.
Is that how they are supposed to be or is there some trick to getting the springloaded feet to unlock so the N2 actually sits on the 4 rubber tipped feet?
ANother question wrt to the WeChip G30s remotes.
Was able to progam power ON on the G30s by learning from an ODroid remote. However, I found that you had to Press the TV button to allow the Power button to work to switch the unit back on but in that mode the Android/KODI and Airmouse functions don't work so you press the TV button to re-enable them. I then reasoned that maybe programing the G30s default ON remote code into Corelec following the Putty SSH, Nan+ Config editing guid earlier in the thread might solve this little issue. It doesn't. Remote wouldn't send the code until I toggled the TV button. ie. It seems to me that the remote can be in 2.4g WIrelss mode or IR mode but not both at the same time, the toggle between the two being the TV button. I know its a small thing but its annoying all the same, having to remember to Toggle the TV button to enable the ON Button to turn the unit ON and then Toggle the TV button again to re-enable remote control/Airmouse.
Is there something I am missing/doing wrong or is this just the way it is?
Anyone?
Currently need to toggle WeChip G30s between Wireless and IR mode with the TV button to activate the Power On/Off button before using it and toggle back to activate all the other buttons for KODI. Is this normal or am I doing something wrong?
nickr
Retired Team-Kodi Member
OK so I have not read ALL the posts in this thread, but does anyone know where and when this beast might be in stock. I don't really mind if it doesn't have a coreelec sticker...
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
nickr
odroid.co.uk was one place I hadn't tried as it is even further away from me than Korea or the USA. But I had seen that link, thanks for your reply.
