Upgrade python from a fork kodi 16
Hi im trying update python 2.6 to 2.7 on a fork wetek mediaplayer on android, i need use jarvis apk for amlcodec
https://github.com/christiantroy/xbmc/releases/
On windows following this thread i can upgrade version python following this thread
https://forum.kodi.tv/showthread.php?tid=322821
Do you know how do it the same on android? i dont know which folders dll and lib are to replace the files..
Or if anyone can compile me a wetek mediaplayer with python 2.7 i would appreciate it very much from this source
https://github.com/christiantroy/xbmc/releases/ v5 for example
If u tell me try latest versions of spmc and ftmc, i cant use that, because that versions has problems on pvr, on spmc and ftmc latest versions from jarvis, the python 2.7 works very well, but the pvr only works well on the fork wetek media player
I tried unpack ftmc.apk change files assets/python2.7 to wetek.apk unpacked with apktool and repack, it install, but python doesnt works
Help me please
Thanks 4 all!
nobody can help me? i unpacked two apks one with python 2.7 and another with python 2.6.. and i view this files in assets folder.. Sad
You need to deal with core code changes too, hacks like repacking will not work.
Omg , thanks too i dont know how do it Sad ty
Upgrade python from a fork kodi 160
