Yanta
Senior Member
Would it be possible to add M and MA as movie ratings?
Would it be possible to have tmm ignore files/folders that are hidden (like Kodi does)?
Please and thank you.
myron
Posting Freak
1) Maybe. From what country are M/MA?
2) We ignore some sort of hidden files/folders, when starting with a dot (Unix style)
But i guess, you just mean the hidden flag in windows...? should be also doable...
myron
Posting Freak
1) works for me.
Set your certification language to Australia (scraper settings), and scraped "Escape Plan 2: Hades!" with IMDB.
You can only scrape ONE language!
Certification MA15+ scraped...
... and correctly written to NFO (NFO settings - certification style)
just tested this example and it has been detected the right way: NZ:M has been detected using the imdb scraper
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at
Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at
GitLab
I think Yanta is from Australia, so wants Australia:M to be compatible with studio icon lookups in skin. NZ uses a different icon.
sorry - I missed that you are wanting certs for Australia..
BUT - this is also working for me? Just make sure you have Australia chosen in the settings
on the other side: IMDB is awful to scrape; they _can_ offer different web pages based on your IP address - maybe this hits you :/ I'd suggest to take as much as possible from TMDB!
GitLab
please do not use any "Kodi: ..." scraper unless you really need to!
these are the original Kodi scrapers (which can be used inside Kodi) which have been made "compatible" with tmm.. they are not as integrated as the native tmm scrapers. If you make more tests, please use the tinyMediaManager scrapers (maybe you have used the Kodi IMDB scraper and all your posts from above refer to this scraper?)
GitLab
Yanta
Senior Member
2019-06-17, 13:16
(This post was last modified: 2019-06-18, 13:03 by Yanta.)
Might be a no-brainer for you. I've only been using the software for 48 hours.
Using 2 above I do not get the certs unless I update source, get mediainfo then manually rescrape every movie which took 7 hours and got about 80% of the M's and MA15's.
I'm now trying your 3 above.
I was looking for an entry called "TMDB", hence the confusion. I was not looking for "themoviedb.org".
Anyway, I have bigger issues than the certs. I have about 1,000 hidden folders. tMM scans every folder in the source.
So adding an exclusion for \\server\folder1 in the following structure..
\\server\folder1\folder2
\\server\folder1\folder3
Will only exclude the contents of \\server\folder1. folder2 and folder3 will be scanned unless I add exclusions for each of those.
With 1,000 of those it's taking time to add them. That is my current focus. Actually, its taking forever to add exclusions 1 by 1. I think I'll wait see if handling of hidden folders is added
Thanks for all your help with the certifications.
