2019-10-04, 11:50
(This post was last modified: 2019-10-13, 14:26 by DaveBlake.
Edit Reason: Mark solved
Kodi has stopped playing MP3 files. My music is on Qnap hard drive and this week Kodi will no longer play the files. When select a file to play it boots it back to menu of the Amazon Fire TV and the Nvidia-shield. It will play MKV movie files, but not the MP3 music files. It was working fine for years, but all sudden it stopped working. I uninstalled and reinstalled Kodi and worked for a while, but then it stopped working again. Has anyone experienced this issue? Any help would be greatly appreciated fixing this issue.
I installed log viewer for Kodi, but it's not showing any logs when I run it. Another thing is it does not show any type of error when I select the MP3 to play. It just closes the program and returns to the menu of the Amazon Fire TV and the Nvidia Shield.
I have noticed the same issue with my Intel NUC with embedded Radeon RX 540 graphics. Kodi became unable to reproduce any low quality compressed sound such as DD and MP3. Both in video files and just audio.
This happened after Windows 10 on its own has downloaded and installed Adrenalin Lite software for Radeon. Uninstalling this utility has helped to restore the KODI functionality.
It is not you case but may be you or KODI itself has updated some plug-ins/addons/themes...
Please see the below video of the issue.
Klojum
Lost connection
Yes, Kodi stops. Now where is the log file?
jjd-uk
Team-Kodi Member
2019-10-06, 13:16
(This post was last modified: 2019-10-06, 13:17 by jjd-uk.)
Are those mp3 audio files, or are these videos with mp3 audio as you are in the Video section of Kodi and not the Music section?
