can you show me a screenshot how to setup trailers? i made TMDB as my primary scraper but its still not adding trailers. also, would it be possible to use IMDb ratings instead of TMDB while using TMDB as a primary scraper?
is tvdb scraping still broken?
Can you put the date in your version info or about screen
so we can know which daily build we got installed.
Nosfé
Junior Member
OK, it's not a big deal anyway.
Other question, I now try to scrape my movies, and I've already renamed them like that "Movie_Name (Original Movie Name) (YYYY, realisator).mkv but scraper can't find anything.
So I have to remove everything after "Movie_Name" to find something.
Is there a way to exclude that is betewen parenthesis?
2020-12-07, 16:06
(This post was last modified: 2020-12-07, 16:09 by tiny-starship.)
the download link in the first post does not seem to be working, is it just me? Anyone know where else to download?
never mind, i had to copy the link, open a new tab and paste it there to get it to work.
Hello,
to to the issue that Kodi do not really read all metadata of my BD-Isos in storage pool i installed EMM. Great tool but i notice some issues. First issue is that i am not be able to get the German title of the movie. It is always the same as the original. I select all fields in options to get German names but nothing works. Second is it correct that no short discription will be load for movies from tmdb? At least when i want to scrape all movies at once no iso metadata will be load. The messages will appear that the metadata are loaded or scraped but they do not. I have to manual select the refresh button for each movie on the right window site or click strg + i.
It seems that EMM should wait minimum 8 to 10 seconds for each loading of an iso to get the metadata before to scrape the next. Finally is it normal that the time for downloading a HD trailer from youtube takes several minutes?
HTPC: Windows 10 Pro 22H2, Zalman HD135, Intel i3-7100, GTX 1070, UHD ASUS BW-16D1HT
NAS: Xpenology 7.2 Update 1, Intel i5-6600
