Is there any plan/ability for this YT plugin to support
the speed option that exists when using YT via a browser?
(For example the ability to increase playback speed in
settings to 1.25x, 1.5x, 2x speeds)
Thanks!!!
Running Kodi 17.6 on NVIDIA Shield.
Finally got my own youtube api key to work (no exceeded limit messages now), but now I am unable to login - login failed: code 401.
Tried all the options under maintenance
Anyone know how to fix this?
Emby, NVIDIA Shield, QNAP
how do i enter links to play directly? I'd like to play unlisted videos.
2018-01-02, 01:30
(This post was last modified: 2018-01-02, 04:05 by ykhehra1.)
I need some help, I have
I have some yt channel IDs on my pastebin
If my addon call yt plugin with xbmc.PlayMedia it just start start playing videos of channel from 1st videos as a playlist. I want yt plugin to list the videos and let user to play the one as needed.
url = plugin://plugin.video.youtube/channel/[CID]/
xbmc.executebuiltin("xbmc.PlayMedia("+url+")")
I guess I need to use
ActivateWindow(10025,'plugin://plugin.video.youtube/channel/[CID]',return)
but its not working for me as I am not getting how to use given CID from my pastebin.
here is what I am trying to do:
CID = url
def ytchannel(url):
url = 'plugin://plugin.video.youtube/channel/' + url +'/'
xbmc.executebuiltin("ActivateWindow(10025,'("+url+")',return)")
and this is what I get in log"
16:58:58.395 T:26304 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
16:59:00.895 T:26304 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol('(plugin) in '(plugin://plugin.video.youtube/channel/UC3o_gaqvLoPSRVMc2Gm****/)'
16:59:00.896 T:26304 ERROR: CGUIMediaWindow::GetDirectory('(plugin://plugin.video.youtube/channel/UC3o_gaqvLoPSRVMc2Gm****/)') failed
16:59:02.980 T:21200 ERROR: Could not find suitable input format: x-directory/normal
What I am doing wrong or how I manage to use given channel ID Playlist ID from my pastebin to list the videos.
2018-01-04, 00:49
(This post was last modified: 2018-01-04, 00:51 by wheemer.)
Hello;
I find the chrome extension Kassi very helpful when entering the API keys.
You can send text to Kodi.
I've had it working in LibreElec 9 for a while now.
Everything I watch with this addon does not get marked as watched on youtube.com
Is that working? I really want to ensure my views are counted and the video stops being suggested to me on the top of my feeds.
Also is there a way to pop up a thumbs up or thumbs down at the end of the videos? I would like to have my vote count.
Using this in conjunction with Youtube Library addon and videos just pop up in my tv shows as they come out.
2018-01-09, 02:29
(This post was last modified: 2018-01-09, 03:02 by blueribb.)
I'm getting the error message "Invalid Parameters" on all my machines when trying to play any video on the YouTube Add-on. Am I the only one ?
This is on version 5.5.0~alpha 12 & 14
Update: I installed version 5.4.5 and it works OK
I been using YouTube add-on on my raspberry pi running osmc for quite some time. I did not have trouble playing up to 1080p 60fps videos but today YouTube will not play videos above 720p. Is YouTube itself at fault?
I am also getting "Invalid Parameters" on alpha, all videos cannot play
