duk81
Junior Member
I'm not sure if it's just me or not, but for some reason I'm not able to update or access the repository that this is located on. I'm stuck on 0.2.6 as of now. I keep getting an error that the repository can't be reached. Any help would be greatly appreciated. Thanks.
Hello guys, i just wanted to say a big THANK YOU to all involved in this app.
I managed to install kodi on firestick tv (1080p version one) and then I installed this addon for diseny plus.
I enabled widevine L1 support and now I can finally enjoy disney plus in 1080p with properly 5.1 support for my setup up.
Again, thank you thank you thank you
gus92
Junior Member
I installed the disney+ addon in my nvidia shield with kodi 18.5 and inputstream adaptive 2.4.5. It works fine but I found a problem with the subtitles. I have selected Spanish as default language for subtitles in the kodi's preferences, but the Spanish subtitle track is never selected automatically when using the disney+ addon.
I think the addon renames the audio track IDs such as "es-ES", "fr-FR" to "es","fr" (and so on) so that kodi could recognize those languages correctly but it doesn't do the same for the subtitle track, I think this is what is causing the problem. Can this be fixed?
2020-09-04, 02:31
(This post was last modified: 2020-09-04, 02:31 by matthuisman.)
are you using VPN / smart dns by any chance?
If so, does their website work OK using the same VPN / smart dns?
Sorry, talk about vpns is not allowed on these forums.
I was just checking to see if that was your issue.
gus92
Junior Member
I had the same idea and I made some (ugly) modifications to script.module.slyguy to support several options: it's possible to disable the audio description tracks and the forced subtitles, select the preferred audio codec and select the preferred languages for audio and subtitles.
I don't know if I'm allowed to post the modified file here.
