2009-02-03, 12:09
Automatic refreshrate changing does not work when playing videos.
I noticed these in xbmc console output
cannot find mode 0x10d
With ubuntu binary xrandr mode changing using ID works fine.
I tried to compile xrandr from ubuntu sources, then xrandr has the same problem. See the copy pastes below.
For a workaround, I changed xbmc to use ubuntu binary for mode changes, and xbmc-xrandr for fetching the modes.
Distribution: Ubuntu 8.10 x86_64 2.6.27-9-generic
XBMC: revision 17558
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# xrandr --output default --mode 0x10d
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for XRANDR... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# make
make all-am
make[1]: Entering directory `/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr'
gcc -DHAVE_CONFIG_H -I. -g -O2 -MT xrandr.o -MD -MP -MF .deps/xrandr.Tpo -c -o xrandr.o xrandr.c
xrandr.c: In function ‘set_name’:
xrandr.c:434: warning: format ‘%x’ expects type ‘unsigned int *’, but argument 3 has type ‘XID *’
xrandr.c: In function ‘main’:
xrandr.c:2274: warning: format ‘%x’ expects type ‘unsigned int’, but argument 2 has type ‘RRMode’
xrandr.c:2310: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘long unsigned int’
xrandr.c:2310: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘long unsigned int’
xrandr.c:2316: warning: format ‘%x’ expects type ‘unsigned int’, but argument 2 has type ‘XID’
xrandr.c:2317: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘Time’
xrandr.c:2382: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘long int’
xrandr.c:2382: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘long int’
xrandr.c:2426: warning: format ‘%x’ expects type ‘unsigned int’, but argument 3 has type ‘RRMode’
xrandr.c:2487: warning: format ‘%x’ expects type ‘unsigned int’, but argument 3 has type ‘RRMode’
mv -f .deps/xrandr.Tpo .deps/xrandr.Po
gcc -g -O2 -o xrandr xrandr.o -lXrandr -lXrender -lX11
sed -e 's|__vendorversion__|"xrandr 1.2.3" "X Version 11"|' -e 's|__xorgversion__|"xrandr 1.2.3" "X Version 11"|' -e 's|__xservername__|Xorg|g' -e 's|__xconfigfile__|xorg.conf|g' -e 's|__projectroot__|/usr/local|g' -e 's|__apploaddir__||' -e 's|__appmansuffix__|1|g' -e 's|__libmansuffix__|3|g' -e 's|__adminmansuffix__|8|g' -e 's|__miscmansuffix__|7|g' -e 's|__filemansuffix__|5|g' < xrandr.man > xrandr.1
make[1]: Leaving directory `/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr'
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# ./xrandr --output default --mode 0x10d
./xrandr: cannot find mode 0x10d
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# ldd xrandr
linux-vdso.so.1 => (0x00007fffb09fe000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x00007ffea849f000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007ffea8295000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007ffea7f8d000)
libc.so.6 => /lib/libc.so.6 (0x00007ffea7c1b000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007ffea7a09000)
libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x00007ffea7807000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007ffea75eb000)
libdl.so.2 => /lib/libdl.so.2 (0x00007ffea73e7000)
/lib64/ld-linux-x86-64.so.2 (0x00007ffea86a7000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007ffea71e5000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007ffea6fe0000)
root@bogey:/home/jukka/linuxport/XBMC/x11-xserver-utils-7.3+5/xrandr# ldd /usr/bin/xrandr
linux-vdso.so.1 => (0x00007fff9b5ff000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x00007f1a93187000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007f1a92f7d000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f1a92c75000)
libc.so.6 => /lib/libc.so.6 (0x00007f1a92903000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007f1a926f1000)
libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x00007f1a924ef000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f1a922d3000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f1a920cf000)
/lib64/ld-linux-x86-64.so.2 (0x00007f1a9338f000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f1a91ecd000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f1a91cc8000)
root@bogey:/home/jukka/linuxport/XBMC# ./xbmc-xrandr
<screen id="0" minimum_w="640" minimum_h="480" current_w="1680" current_h="1050" maximum_w="1920" maximum_h="1080">
<output name="default" connected="true" w="1680" h="1050" x="0" y="0" wmm="0" hmm="0">
<mode id="0x10d" name="1680x1050" w="1680" h="1050" hz="50.00000" current="true" preferred="false"/>
<mode id="0x10e" name="1680x1050" w="1680" h="1050" hz="48.00000" current="false" preferred="false"/>
<mode id="0x10f" name="1680x1050" w="1680" h="1050" hz="60.00000" current="false" preferred="false"/>
<mode id="0x110" name="1280x1024" w="1280" h="1024" hz="75.00000" current="false" preferred="false"/>
<mode id="0x111" name="1280x1024" w="1280" h="1024" hz="60.00000" current="false" preferred="false"/>
<mode id="0x112" name="1280x960" w="1280" h="960" hz="60.00000" current="false" preferred="false"/>
<mode id="0x113" name="1152x864" w="1152" h="864" hz="75.00000" current="false" preferred="false"/>
<mode id="0x114" name="1024x768" w="1024" h="768" hz="75.00000" current="false" preferred="false"/>
<mode id="0x115" name="1024x768" w="1024" h="768" hz="70.00000" current="false" preferred="false"/>
<mode id="0x116" name="1024x768" w="1024" h="768" hz="60.00000" current="false" preferred="false"/>
<mode id="0x117" name="800x600" w="800" h="600" hz="75.00000" current="false" preferred="false"/>
<mode id="0x118" name="800x600" w="800" h="600" hz="72.00000" current="false" preferred="false"/>
<mode id="0x119" name="800x600" w="800" h="600" hz="60.00000" current="false" preferred="false"/>
<mode id="0x11a" name="800x600" w="800" h="600" hz="56.00000" current="false" preferred="false"/>
<mode id="0x11b" name="640x480" w="640" h="480" hz="75.00000" current="false" preferred="false"/>
<mode id="0x11c" name="640x480" w="640" h="480" hz="73.00000" current="false" preferred="false"/>
<mode id="0x11d" name="640x480" w="640" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0x11e" name="480i/60" w="640" h="480" hz="30.00000" current="false" preferred="false"/>
<mode id="0x11f" name="480p/60" w="640" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0x120" name="720p/60" w="1280" h="720" hz="60.00000" current="false" preferred="false"/>
<mode id="0x121" name="1080i/60" w="1920" h="1080" hz="30.00000" current="false" preferred="false"/>
<mode id="0x122" name="1080p/60" w="1920" h="1080" hz="60.00000" current="false" preferred="false"/>
</output>
</screen>
