reaven
Skilled Skinner
2009-08-20, 08:39
(This post was last modified: 2009-08-20, 08:51 by reaven.)
what the nfo have anything to do with the flag position?
with the new native flagging support the only thing related to the flags in the nfo is the studio name.
anyway I found the "Furniture_EpisodeMediaFlagsVars" for multiplex I willp lay woth that..
HELP ME PLEASE
not find the option Extract media metadata information in my XBMC.Myflags not appear complete only appears company,not show audio and video. what is happening?
I tried everything and nothing, I use Ember Media Manager to generate NFO
THANKS
Oh, forgot to change the first post. When you download and unzip the skin from github you do not need to download the zip file from mediafire or extract anything special. Since the github download includes a complete skin just extract it to your XBMC skin folder.
This mod is designed to use the meta data that XBMC extracts from the files. It DOES NOT use the filename for anything but the source logos (Blu-Ray, DVD, HD-DVD). it also DOES NOT use the studio tag to read the codec information.
You need to enable the extract media meta information feature of XBMC. Then XBMC will read the information from the files and the flags will display properly.
I also do not know how this works in combination with the other mod you described. I think most mods should have native media flagging integrated by now. Hitcher for example has all that already included.
Thanks, now i can see all the featuresfub i can see the ? at back of each logo.
what can i do to take them out?
THANKS
help please 2
I installed xbmc svn my flags appeared but now no sound of movies in 5.1 DTS, before I had with xbmc 9.04,how to fix it?XBMC SVN NO SOUND 5.1DTS AND XBMC 9.04(DOWNLOAD OF SITE OFICIAL) HAS SOUND
thanks
