2009-09-02, 20:14
Hi Ronie,
just downloading v2, will let you know how I get on
Thanks for all your hard work
whipper Wrote:Wow Ronie great work once again! The new additions are awesome!
You helped me tweak 1.03. I went looking in Home.xml to do the same again but can't find it ?
Where would I look now to change favourites to something else and go straight from games tab to launcher?
Hope you don't mind
whipper Wrote:Hi Ronie , thanks beat me to it. I did find it AND managed to change it myself!
Now theres just one little thing, once you've pushed favourites tab, a panel opens also named/labeled favourites is it possible to rename that too?
If not or if its a hassle for you, not to worry I'm happy as a pig in S...! as it is really
Vampirebat Wrote:i do have a request for Ver 3.0 in the slide view is it possible to squeeze in a scroll bar at the bottom below the movie thumbs for fast scrolling thru large libraries?
darknior Wrote:why when i go to Movies or TV Show i have the same folders ?Is the library enabled (ON)
Why i can't separate them to have different ?
darknior Wrote:And in the setting you speak about FILM and in the HOME MENU you write SEQUENCE ... it must be the same name for the twoSEQUENCE is from XBMC, not Transparency!, I have sent XBMC a correction
darknior Wrote:Hi
I have test your version 2.0, and it is impressive to see all you have add
But for my part on xbox, i have many more FREEZE of the xbox for low memory
Do you know what you hava had who use all the memory ?
Because i use your xbox version of 2.0 transparancy!
darknior Wrote:Other thing, why when i go to Movies or TV Show i have the same folders ?
darknior Wrote:Finaly, on the setting i have two options in french i don't understand
I must choose by "fanart -" or "fanart -" ... the string is not complete
Bram77 Wrote:You could try using the skin-based madia flagging (morer info in startpost). That might reduce memory usage, but I'm sure.
darknior Wrote:I have test your version 2.0, and it is impressive to see all you have add
darknior Wrote:I must choose by "fanart -" or "fanart -" ... the string is not completeMake sure your using a more recent nightly build as apparently this should fix your idea, but Im also having the same thing Ronie recommended to look at the strings.xml file for a couple of strings to make sure their present. So, look at that and check/verify if your using a recent nightly build as mentioned in this thread on a previous post by Ronie.
ronie Wrote:i'm no expert on the inner working of xbmc, but skin based flagging will increase memory usage. the skin will have to load all the available flags into the memory, while with native, it doesn't.
