2011-02-17, 00:34
Hi Adam:
Just tried to upgrade to svn (924) and got a database connection error that I haven't seen before. (mythicalLibrarian has been working fine, but in the grand tradition of fixing what isn't broken, I decided to upgrade since it had been a while since I had...)
Here's what was output during --upgrade:
...as I said, nothing has changed on my setup, I'm running MythTV 0.24-fixes on 10.04.2. I can successfully login to mysql from the commandline using the user mythtv and the password that was given to mythicalLibrarian in setup.
Anything else I can check on my end?
/Greg
Performing MythTV Python Bindings database test
/usr/bin/python2.6
Python2.6 installed
Establishing database connection
Failed: attempting to use system default configuration
Connected to: arbormyth
Db Identified as: sql://mythconverg@localhost:3306/
Diagnostics passed.
Diagnostics failed.
File "<string>", line 1, in <module>
ImportError: No module named MythDB.MythTV
/usr/local/bin/mythicalLibrarian: line 1783: test: too many arguments
Diagnostics passed.
Diagnostics failed.
there was a problem connecting to the database, check MythDatabase package
MythTV Database Test ***FAILED***
/Greg
