use this one
http://hub.gosub.dk/addons/script.audio....-fixed.zip
dont forget to delete everything with groove in the name in
../addons/
and
..userdata/addon_data
macf1an Wrote:they acutally don't have to delete anything I made the zip so it overwrites the old one
Oddly, I tried to install it directly from .zip hub.gosub.dk and it didn't take, had to install it manually to get it to work. Works great, thanks.
2012-04-04, 15:04
(This post was last modified: 2012-04-04, 15:55 by rflores2323.)
Can you pls try to make this alittle more touchscreen friendly. currently when I try to select a song the right menu comes out but goes right back and u cant select it as it goes back way to fast. also no osd menus come up also when a song is selected. There is no way to pull up the right or left menus as there is no buttons on the interface.
also is there a way you can add subscriptions to this script? Would be nice as my wife and I subscribe to each other and we use it like a master playlist for both of us. Also our friends aswell.
thanks. great work
Nvidia Shield with Kodi 18
I can't seem to get it working.
Could someone please upload the fixed Grooveshark.py.
It get the stream only and no working
i think i have the same problem with the plugin now cant even use the site
