2011-10-25, 01:30
TobiasTheCommie Wrote:Please just wait for us to push the next 2.7 beta. It is really close.
And we're pushing a stable 2.1.2 today.
Ok thank you.
Pednick Wrote:Login is ok now but the watch later folder says it's empty when it's not.
TobiasTheCommie Wrote:Please prove a debug log.
There is no watch later in 2.1.2. It works trunk, but may be broken in 2.6.3.
Pednick Wrote:http://pastebin.com/aiEH6Qf4
TobiasTheCommie Wrote:Yeah, broken in 2.6.3.
It will be fixed in the next beta.
Big_Noid Wrote:Why does this add-on sets everything to container.content(movies)?
There are no movies on youtube :confused2:
wizardpc Wrote:Both my systems autoupdated to 2.1.2. Both won't log in. Both are 64 wintel. Originally installed via repo.
http://pastebin.com/Cv6s0Rtv
I also use Google's two factor authentication. First thing I did was create a new application specific password, thinking that maybe the update had jacked up the stored PW. I get no indication in the UI that login failed, I just dont have access to my folders.
TobiasTheCommie Wrote:You have to log in with real two factor authentication. Not using an application specific password.
If you don't want your password stored you can leave it blank, and the addon will ask you for password. ( Sadly i just noticed that it doesn't specify if it is asking for the password, or the authentication key. )
wizardpc Wrote:That doesn't work either.
KeithLM Wrote:I can enter data in the login screen, and I can pull up the Play Video by ID log, but the other menu options don't appear to do anything. I can't get to pastebin at the moment, so here's the log file.
