Hi alturismo
I´ve the same problem under OSX and the Log look like yours.
(with ubuntu :Same , but in Win it works fine)
Margro, Thanks for the latest build, updated today and all is working, Is there any way to set the tv channel order to that in Media portal ?
Hi, also can confirm that it works so far, problems with deinterlacing and
bad pic quality on live tv but this seems to be hardware related.
(ion2 no proper drivers i guess, SDTV 50fps but still not smooth, HDTV 720p 50fps jerky, HDTV 1080i 25fps jerky)
thanks for the update
opdenkamp
Retired Team-Kodi Member
2011-03-29, 10:17
(This post was last modified: 2011-03-29, 10:19 by opdenkamp.)
this looks like a problem with the (configuration of the) backend. did you install and configure the cam on the backend (probably acamd)?
edit: didn't read the "it works on windows" part. then I suspect that it is some bug in the add-on itself.
opdenkamp / dushmaniac
xbmc-pvr [Eden-PVR builds] [now included in mainline XBMC, so no more source link here :)]
personal website: [link]
Found a problem with PVR? Report it on Trac, under "PVR - core components". Please attach the full debug log.
If you like my work, please consider donating to me and/or Team XBMC.
Alright thats understandable.
Then my next question is: How can I install an older version on the Live version.
Is there a linux command that makes that possible, cuz I'm a huge noob on Linux.
anyone may knows when mp tv support will be working again ?
