Full Version: Skinning for beginners - Foundation skin, skinning tools, and tips
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
THIS SKIN IS NO LONGER COMPATIBLE WITH CURRENT KODI VERSIONS!
Foundation skin: Updated for Eden
Foundation is a very simple but fully functional skin designed to be used as either a base for creating new skins or as a learning tool for anyone interested in what makes a skin work.
It comes with both 720p & 1080i coded XML's and I've also included a screen shot folder of every window/dialog XBMC uses to make things even easier.
To get the most out of it you'll need to either make a new keymap.xml or add this to your existing one -
PHP Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<keymap>
    <global>
        <keyboard>
            <F5>XBMC.ReloadSkin()</F5>
            <F6>Skin.ToggleSetting(DebugGrid)</F6>
            <F7>Skin.ToggleSetting(DebugInfo)</F7>
            <F8>Notification(Testing 123,Hello world)</F8>
        </keyboard>
    </global>
</keymap>
F5 - Reload skin
F6 - Show/Hide the Debug Grid
F7 - Show/Hide the Debug Info
F8 - Activated the KaiDialogToast.xml
Frodo download
Credit goes to Jezz_X for the textures.
Other useful links -
TexturePacker for Mac OS X
Sublime Text 2 - XML editor
Debugging/skinning aid for any skin
Skin XML Converter
Skin repository creator
How to test Peripheral settings
How to test Karaoke
How to test DialogFileStacking
Eden Update
Changelog -
2.0.1
Added: <!-- Foundation --> tags to all windows
Added: Exit button visible condition
Removed: Dummy controls from DialogPeripheralManager.xml and DialogPeripheralSettings.xml
2.0.0
Changed: Debug grid and Window/Dialog label handling (see Custom_Debug_Overlay.xml)
Changed: Activate Video window controls
Changed: DialogContextMenu.xml
Changed: DialogButtonMenu.xml
Added: DialogPeripheralManager.xml
Added: DialogPeripheralSettings.xml
Added: DialogPeripheralManager.jpg
Added: DialogPeripheralSettings.jpg
Removed: MyVideo.xml
Removed: MyVideo.jpg
Donations for this skin gratefully accepted
Awesome, Very helpful for newbie skinners / modders like myself!
Cool need a new "Basic" skin, when I tried using "Basic" as my base for Carmichael I got all these odd positioning errors and just odd errors in general that werent solved till I moved to Confluence as my base...
