eskro Wrote:what about something like this
I have nothing against your recommendation, but, what would be the advantage of purchasing your mother vs the one i have, which is 69 dollars cheaper. I'm honestly asking, since again, have been out of all this for a while, and can not find any obvious advantage.
[CPU] Intel Celeron E3400 Dual-Core 2.6GHz LGA-775 65W ($44 + $0)
[MOBO+iGPU] ZOTAC G45ITX-B-E X4500HD LGA-775 WiFi-N mITX ($109 + $5)
[CASE+PSU] Apex MI-008 Black mITX 250W ($45 + $0)
[FAN] SilenX IXP-74-09 120mm 800RPM 38CFM 9dBA ($13 + $0)
TOTAL: ($216)
[MOBO+iGPU] Zotac NF610I-K-E Core 2 Quad/ GeForce 7050/ DDR2/ A&V&L/ Mini ITX Motherboard ($45)
TOTAL: ($147)
THANKS!
well, its on you, but DDR3 ram is cheaper then DDR2..
shop around...
and the ZOTAC G45ITX-B-E has WiFi-N built-in
and also can play 1080P without requiring a video card,,,
oh yeah, ZOTAC G45ITX-B-E is Giga-Lan compatible,,,,
eskro Wrote:well, its on you, but DDR3 ram is cheaper then DDR2..
shop around...
OK, wifi is an advantage, agree.
DDR3 vs DDR2 would be checking prices.
You imply that the Zotac NF610I-K-E would not be able to play 1080p? i assumed that would be more of a processor issue, being the celeron a 2.6 ghz proc.
This would be also important, but since i'm going to add one of the 3D capable cards, which run about for 60, that would make the Zotac NF610I-K-E + 3d card about the same price, but with 3d capabilities.
Besides what you already commented, do you see any DISadvantage or ISSUES with the Zotac NF610I-K-E plus a GT430 or HD6450?
ZOTAC G45ITX-B-E = LAN: 10/100/1000
ZOTAC NF610I-K-E = LAN: 10/100
ZOTAC G45ITX-B-E = PCI-Express 2.0x16: 1 (good for video cards)
ZOTAC NF610I-K-E = PCI-Express 2.0x16: none (not good for video cards)
eskro Wrote:ZOTAC G45ITX-B-E = LAN: 10/100/1000
This is not important for me.
eskro Wrote:ZOTAC G45ITX-B-E = PCI-Express 2.0x16: 1 (good for video cards)
This is very important
EDIT: it says: Slots: 1x PCI-Express x1 Slot, which is not very clear. You mean this is PCI Express 1.0 instead than 2.0?
The Zotac NF610I-L-E Desktop Motherboard - Nvidia - Socket T LGA-775 4GB DDR2 SDRAM 4 USB 2.0 Ports, costs $60, and it says: 1 x PCIe x16 Slot.
eskro Wrote:here are the boards that have PCI-Express 2.0x16
http://www.newegg.com/Product/ProductLis...rchInDesc=
You read my mind, I was just checking that.
I love the idea of the E350 motherboard, but i'm a little worried about the E350 performance. So, this is why I'm looking for any alternative with bigger processor.
I would like to have 3D movies capabilities, since I have a 3D Ready Proyector.
I thought it would be easier to get an Atlhon or something similar, but it looks like not.
no,,, PCI-express is not 2.0
eskro Wrote:no,,, PCI-express is not 2.0
Crap, so what should it say? 2.0?
it doesnt say,,, it says PCI Express x16: 1
eskro Wrote:your cheapest way too get there...
I have researched this on AMAZON (newegg would not allow me to pay with my international CC, suckers).
Intel Celeron E3400 Processor 2.60 GHz 1 MB Cache Socket LGA775 $48
ZOTAC GeForce WiFi LGA 775 Mini ITX Intel Motherboard G45ITX-B-E $125
MI-008 Tower Black P4 Chassis with 250W Itx Psu+sata Power Supply $50
Scythe Slip Stream SY1225SL12SL - Case fan - 120 mm $12
Kingston ValueRAM 4 GB Kit (2x2 GB Modules) 1333MHz PC3-1066 DDR3 $29
SUB TOTAL $264
Now, since I want to be able to playback 3D to my Optoma GT700, I was wondering which one would be the best option:
Sapphire Radeon HD 6450 1 GB DDR3 HDMI/DVI-D/VGA PCI-Express Graphics Card 100322L $50
or
Evga GeForce GT 430 1 GB DDR3 PCI-Express 2.0 Graphics Card $63
I rather have the Sapphire, as it is cheaper, but if the evga is better, so be it.
Anyway, adding either card would, more or less make it around 310 + 50 for a HDD, around $360.
Ignoring the E350 ones, would this be the cheaper system?
