Ok guys, sorry for all the confusion, and thanks for all the help.
What I need is a machine capable of:
Playing 1080p movies (mkvs mostly)
Playing 720p movies (again mkvs)
Playing 3D movies (don't know if they are 1080p or 720p)
Emulators and some gaming (mostly MAME, so the most processor for the buck the better).
Finally the machine would probably be on 24x7, mostly downloading/streaming.
I have NO processor/motherboard preference.
I do know that I need one of the 3D capable cards.
I rather have mini itx than micro atx, but is not that big deal.
I was thinking about 200 for mother/proc, about 50 for the case, about 30 for the memory, and about 50 for the 3D card.
That said, I found this on Amazon (I rather avoid newegg, but if there is a really good option there, I can try newegg).
The AM3 Options:
GIGABYTE GA-E350N-USB3 $120
Asus M4A88T-I DELUXE $125
Zotac 890GITX-A-E Socket AM3 $126
If I'm not mistaken, with either, I can fit:
AMD Athlon II X2 250 $60
AMD Athlon II X2 255 $65
AMD Phenom II X2 555 $88
AMD Phenom II X2 560 $90
So there is a 30 bucks different there, but the phenoms apparently are much faster. So I would *tend* to like them more.
On the LGA1155 front, I see:
ASUS P8H61-M $80 THIS IS MICRO ATX
Asus P8H61-I LGA1155/ Intel H61(B3)/ DDR3/ A&GbE/ Mini ITX Motherboard $80
Gigabyte GA-H67N-USB3-B3 $99
Procesors I only see:
Intel Pentium G620 Dual Core 2.6 $75
Intel Pentium G840 Dual Core 2.8 GHz $85
Intel Core i3-2100 Processor 3.1GHz $125
As far as I see, the best option is:
Total 205.
What do you think guys? THANKS!
by the way, ESKRO, you said you would choose the
Asus HD6450 Silent and not the
Sapphire Radeon HD 6450. Both are $50, but the Sapphire has 1GB RAM vs Asus 512MB. What is your reason?
