Full Version: iTV Player for XBMC Eden
Pages: 1 2 3 4 5 6 7 8 9
Is there a way or anything to get iTV player on Eden?
I have seen it but posts were way back in 2008 or so.
Is there somewhere that its up to date?
Or somewhere I can install it?
Thanks guys.
Anyone know this?
Or BBC iPlayer?
SavellM Wrote:Anyone know this?
Or BBC iPlayer?
BBC iplayer
http://forum.xbmc.org/showthread.php?tid...bc+iplayer
Bump...
Anyone able to get itv player?!
SavellM Wrote:Bump...
10/11/2011
http://forum.xbmc.org/showpost.php?p=932...tcount=240
dlake02 Wrote:Hi
New update for ITV Player on:
http://code.google.com/p/xbmc-itv-player/
Main changes are that the plugin will now use it's own proxy settings and that you can declare the maximum stream rate (or default to auto).
These options are available on the plugin settings page, right-click to reach the settings.
Large portions of this code has been culled from exobuzz's EXCELLENT iPlayer plugin - respect.
D
I won't make any sarcastic comments about using the forum search facility :-)
Thanks but doesnt seem to work on Eden!
When I try to go into anything, eg The X Factor it comes up with:
Error Script Failed: Plugin.Video.ITV_1.0.5
Any ideas?
Or did I not install it correctly?
SavellM Wrote:Thanks but doesnt seem to work on Eden!
Any ideas?
I get exactly the same thing everytime i try to a programme from it too.
I think this plugin only works if you are in UK otherwise it won't? If you are in UK then asking in the forum thread might give you quick response.
hunkyn Wrote:I think this plugin only works if you are in UK otherwise it won't? If you are in UK then asking in the forum thread might give you quick response.
I am in the uk and getting the same problem...Big Grin
same here thanks to all who make things happen though
Any ideas?
Hi I'm running the very latest nightly build from xbmc.org on my windows xp pc and the ITV plugin is working great for me
Here is a link to the latest nightlies
http://mirrors.xbmc.org/nightlies/win32/
I installed the addon - plugin.video.itv_1.0.5.zip
Here is a link to the ITV addon
http://code.google.com/p/xbmc-itv-player/downloads/list
I placed the downloaded zip file on the windows xp desktop
Then from the XBMC gui went into System/Addons/Instal from a zip
To install the addon
Then I made two folders one called Subtitles and one called Images at the following location :-
C:\Documents and Settings\HP_Administrator\Application Data\XBMC\userdata\addon_data\plugin.video.itv
you will now if you are in the right folder if you see an existing file called settings.xml.
Do the following if you can't see the above mentioned Application Data folder
remember this is for windows XP
Click Start
Click my computer
Click tools at top of screen
Click Folder options
Click the tab "view"
Click show hidden files and folders
Click apply
Click ok
Then you must replace two files
One is called "addon.xml" and the other is called "default.py"
You can find these files at the following link :-
The folder that you put the two new files is :-
C:\Documents and Settings\HP_Administrator\Application Data\XBMC\addons\plugin.video.itv_1.0.5
this is NOT the same location where you made your two folders ie "Subtitles & Images"
Just confirm yes to overwrite each file in turn
Then hopefully your good to go
All credit goes to member "dlake02" which I found the info by reading the forums
I hope it helps someoneSmile
Its certainly helped me, thank you very much indeed for sharing the knowledge Big Grin
Instead of showing hidden folders could you not just enter %appdata% into the address bar?
venture007 Wrote:Its certainly helped me, thank you very much indeed for sharing the knowledge Big Grin
Great
unabatedshagie Wrote:Instead of showing hidden folders could you not just enter %appdata% into the address bar?
Oh yes, I didn't know that.
ThanksBig Grin
