2012-07-20, 16:04
(2012-07-19, 23:17)Martijn Wrote: [ -> ](2012-07-19, 23:15)havok1977 Wrote: [ -> ]Once you disabled them they should not re-appear asking again.(2012-06-12, 13:55)Martijn Wrote: [ -> ]Use the Universal scraper
Is there a way to disable/get rid of these scrapers altogether? I'm sick of warning messages about them after boot that offer to disable them only to reappear every time I turn on my HTPC.
You can remove them from the userdata (wiki) folder
Thanks for your reply
Disabling right after startup via the pop up dialog wasn't working for me; allmusic, yahoo music videos and some other movies scraper warnings kept popping up every single time for a few weeks so I used to skip them but was somewhat annoying.
After reading some of this thread I ended up removing them altogether from the /usr/share/xbmc/addons/ folder to be done with it, I don't care for them anyway.
