2012-05-31, 19:46
2012-05-31, 20:30
these are not the latest versions of the scraper. Try to do a force refresh.
2012-05-31, 23:50
reinstalled version 2.1.0( although previous one was the upto date one as well). reapplied the original fix, here's the xml
http://pastebin.com/Qh8sZKFJ
artist xml
http://pastebin.com/eC1cXsV0
there is no error given just keeps on going ina loop asking to renter re enter the album name & artists name.
artist xml
2012-06-01, 01:45
Hey shaktoo, same thing I'm seeing. Just goes in a loop and never gets the info
2012-06-01, 03:45
(2012-06-01, 01:45)aTTilaz Wrote: [ -> ]Hey shaktoo, same thing I'm seeing. Just goes in a loop and never gets the info
I am also seeing the same looping issue. Could it have anything to do with the allmusic.com website change? I notice they redid the website completely.
2012-06-01, 07:57
(2012-06-01, 03:45)paco Wrote: [ -> ]Could it have anything to do with the allmusic.com website change? I notice they redid the website completely.
Yes, that's the problem. Allmusic scraper got broken completely.
2012-06-01, 16:10
I'm only working some days with music in XBMC....
what are alternatives best scrapers for artits and albums?
I tried musicbrianz and last.fm....seems not so good...
especially on album information these both find or provide nothing.
2012-06-01, 17:09
please define nothing
2012-06-01, 17:13
Bladerunner there isnt one ..yet , for artist's Olympia has come up with "Universal scraper " available in the official repo. That uses data from allmusic/ lastfm/musicbrainz and I have tried it and is good but sadly nothing there for albums.
We will have to wait to have allmusic scraper fixed
Olympia BTW is that a Dalek ( your avatar I mean )
2012-06-01, 17:23
musicbrainz for albums currently the best out there. grabs premium covers from fanart.tv.
...and yes. for artists the universal scraper is the way to go. dont bet on allmisic scrapers.
2012-06-02, 01:29
Musicbrainz scraper works if I individually go to each album and refresh, it will pull the info/coverar etct for that album. But when i run a full scan for an entire artist, universal scraper gets the artist info perfectly, but when it comes to the albums musicbrainz scraper doesn't scrap any info
2012-06-12, 13:40
so will this be the end of allmusic.com scraper or will someone try and get this to work?
2012-06-12, 13:55
(2012-06-12, 13:40)shaktoo Wrote: [ -> ]so will this be the end of allmusic.com scraper or will someone try and get this to work?
Use the Universal scraper
2012-07-19, 23:15
(2012-06-12, 13:55)Martijn Wrote: [ -> ](2012-06-12, 13:40)shaktoo Wrote: [ -> ]so will this be the end of allmusic.com scraper or will someone try and get this to work?
Is there a way to disable/get rid of these scrapers altogether? I'm sick of warning messages about them after boot that offer to disable them only to reappear every time I turn on my HTPC.
2012-07-19, 23:17
(2012-07-19, 23:15)havok1977 Wrote: [ -> ]Once you disabled them they should not re-appear asking again.(2012-06-12, 13:55)Martijn Wrote: [ -> ](2012-06-12, 13:40)shaktoo Wrote: [ -> ]so will this be the end of allmusic.com scraper or will someone try and get this to work?
You can remove them from the userdata (wiki) folder
