(2019-07-29, 00:35)robweber Wrote: [ -> ] (2019-07-27, 08:10)Smultie Wrote: [ -> ] (2019-07-26, 22:05)robweber Wrote: [ -> ]Good to know. I'll do some testing on my end with the clean after update function. I'm not seeing anything in your log about it even trying. This is triggered by a monitor looking for the "update completed" condition to be issued from Kodi. Maybe this isn't working?
Thanks,
if you need me to check anything on my side, please let me know!
Ok, after some testing I did notice that the cron timer worked but the "clean on update" setting didn't (as you had said!). Digging in to it more I think I hunted down a fix. I created a github branch, would you mind installing via the zip file and seeing if this fixes your problem? https://github.com/robweber/xbmclibrarya...ibrary_fix
You should see some items in your log file similar to the following when it runs:
VideoInfoScanner: Finished scan. Scanning for video info took 00:00
2019-07-28 17:28:57.125 T:8036 NOTICE: CVideoDatabase::CleanDatabase: Starting videodatabase cleanup ..
2019-07-28 17:28:57.575 T:8036 NOTICE: CVideoDatabase::CleanDatabase: Cleaning videodatabase done. Operation took 00:00
Hhhm, I'm afraid not:
2019-07-29 10:58:18.972 T:1538782080 NOTICE: VideoInfoScanner: Starting scan ..
2019-07-29 10:59:05.731 T:1538782080 ERROR: CCurlFile::Open failed with code 4 04 for
https://api.thetvdb.com/search/series?name=%23recycle:
2019-07-29 10:59:05.731 T:1538782080 ERROR: Run: Unable to parse web site
2019-07-29 10:59:05.898 T:1538782080 ERROR: CCurlFile::Open failed with code 4 04 for
2019-07-29 10:59:05.898 T:1538782080 ERROR: Run: Unable to parse web site
2019-07-29 10:59:06.086 T:1538782080 ERROR: CCurlFile::Open failed with code 4 04 for
2019-07-29 10:59:06.086 T:1538782080 ERROR: Run: Unable to parse web site
2019-07-29 10:59:06.286 T:1538782080 ERROR: CCurlFile::Open failed with code 4 04 for
2019-07-29 10:59:06.286 T:1538782080 ERROR: Run: Unable to parse web site
2019-07-29 10:59:06.290 T:1538782080 WARNING: No information found for item 'smb ://Diskstation/tvshows/#recycle/', it won't be added to the library.
2019-07-29 10:59:06.612 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/A Series of Unfortunate Events/' does not exist - skipping scan.
2019-07-29 10:59:06.616 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/After Life/' does not exist - skipping scan.
2019-07-29 10:59:06.620 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/Game of Thrones/' does not exist - skipping scan.
2019-07-29 10:59:06.625 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/Lilyhammer/' does not exist - skipping scan.
2019-07-29 10:59:06.628 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/The Defiant Ones/' does not exist - skipping scan.
2019-07-29 10:59:06.633 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/The Simpsons/' does not exist - skipping scan.
2019-07-29 10:59:06.637 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/The Sinner/' does not exist - skipping scan.
2019-07-29 10:59:06.641 T:1538782080 WARNING: Process directory 'smb://Diskstati on/tvshows/Workaholics/' does not exist - skipping scan.
2019-07-29 10:59:06.653 T:1538782080 NOTICE: VideoInfoScanner: Finished scan. S canning for video info took 00:47
2019-07-29 10:59:06.720 T:1803527040 WARNING: Repository add-on net.rieter.xot.r epository uses plain HTTP for add-on downloads in path
http://www.rieter.net/net .rieter.xot.repository - this is insecure and will make your Kodi installation v ulnerable to attacks if enabled!
2019-07-29 10:59:06.720 T:1803527040 WARNING: Repository add-on openelec.repo.an calex.arm-2.1 uses plain HTTP for add-on downloads in path
http://addons.anxer.r o/2.1/RPi/arm - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
2019-07-29 11:00:39.332 T:1932914704 NOTICE: Samba is idle. Closing the remaining connections
