2013-02-10, 02:05
2013-02-14, 23:34
I'm gathering this may not work, but figured I would ask.
I have a Pioneer VSX-1014 that does not have HDMI in or out. So, I currently go HDMI -> TV -> Toslink -> AVR. Is it at all possible to still bitstream this way?
2013-02-14, 23:45
(2013-02-14, 23:34)constantcarnage Wrote: [ -> ]I'm gathering this may not work, but figured I would ask.Not DTS-HD and TrueHD audio....
2013-02-15, 11:57
I guess you do it that way because your HTPC doesn't have any Optical out. If it has optical out, you would be much better doing PC HDMI -> TV and PC Optical - > TV
2013-02-15, 22:55
(2013-02-15, 11:57)PatrickVogeli Wrote: [ -> ](2013-02-14, 23:34)constantcarnage Wrote: [ -> ]I'm gathering this may not work, but figured I would ask.
Yeah, the optical out from the TV to AVR is, I thought, just a passthrough for the audio being transmitted over HDMI. I don't think there's an optical in on the TV. Did you mean to say go PC HDMI -> TV, PC Optical -> AVR? Rather than trying to pass through the TV?
2013-02-15, 23:23
(2013-02-15, 22:55)constantcarnage Wrote: [ -> ](2013-02-15, 11:57)PatrickVogeli Wrote: [ -> ](2013-02-14, 23:34)constantcarnage Wrote: [ -> ]I'm gathering this may not work, but figured I would ask.
Passing through the TV you're highly unlikely to get any bitstreaming as most TV's only accept Stereo LPCM on their HDMI input.
2013-02-15, 23:29
(2013-02-15, 23:23)jjd-uk Wrote: [ -> ](2013-02-15, 22:55)constantcarnage Wrote: [ -> ](2013-02-15, 11:57)PatrickVogeli Wrote: [ -> ]I guess you do it that way because your HTPC doesn't have any Optical out. If it has optical out, you would be much better doing PC HDMI -> TV and PC Optical - > TV
Ah.. that would explain it. Thanks!
2013-05-09, 17:53
Hi all,
Quick question RE bit streaming...i have a HTPC with a built in realtek sound card and i have a logitech z5500 system. My questions is simple, can i get XBMC/Windows to decode DTS HD MA and the rest of it and send that over 6 channel analog to the logitech z5500 thus accomplishing bit streaming?
I have read in many places that this may be possible using certain cards and software but my questions relate directly XBMC and if its possible to do this as i dont have an AVR.
Thanks in advance.
Thanks in advance.
2014-06-11, 22:51
I can read in the first post :
My HTPC/NAS run a core i3 3225 with IGPU HD4000 and I don't need to "select Software Renderer", my AVR receives DTS and even MA audio and display the signal type on its front panel.
Isn't that statement outdated? or maybe I miss something?
Quote:Enable DXVA2 with "Auto Detect" as Render Method and disable everything else in XBMC settings/video/playback (Note: if you are using Intel iGPU, you need to disable DXVA2 and select Software as Renderer Method)
2014-06-13, 15:49
(2013-05-09, 17:53)true_devil Wrote: [ -> ]Hi all,
Thanks in advance.
I don't think you understand what bit streaming is.. It is the passing through of audio untouched to the receiving amp done via hdmi
2014-08-11, 13:58
Hi everyone,
One question about my set up:
I can't play Dolby HD file on my XBMC. Movies are lagging and no sound comes out at all.
When I deactivate the DTS in XBMC system audio settings (to chose receiver not DTS HD capable) then movie works fine.
My config:
Zotac ID 63 (i3)
XBMC Gotham
Ampli: Onkyo TX - NR 626 (used in 5.1 config)
Any ideas guys?
Thanks a lot for your help!
P.S: All other movies in simple DTS works all fine)
My config:
Zotac ID 63 (i3)
XBMC Gotham
Any ideas guys?
2014-08-11, 17:02
I forgot to mention, I run on Windows 7
2014-08-12, 08:14
Hi everyone,
Problem solved!
I just missed to configure my XBMC audio settings in WASAPI!
Of course the DTS-HD works only with WASAPI enabled and will not work with Direct sound.
It always sounds obvious when you have the answer, doesn't it?
Now I can enjoy u-571 in DTS HD!
Thanks !
Problem solved!
Thanks !
2014-12-11, 18:46
I am Nooby here. I setup my XBMC and run through my Pioneer Receiver 1020-AHX. I follow all the instructions here and able to hear the 5.1 setup. Everytime i stream movie (1080p), my receiver shows PCM. Is that correct instead of showing DTS, HD MA? Thanks for the advice.
2015-01-25, 00:52
Are you sure what you are streaming are 5.1 files? Even if is 1080p or blue-Ray It will only stream in 5.1 if the stream says that it's 5.1, DD, or DTS.
