2014-06-05, 18:43
2014-06-05, 18:45
Maybe a suggestion to make a XBMC version depending check/conversion?
2014-06-06, 07:01
(2014-06-05, 18:43)Bumpaneer Wrote: [ -> ]Travelling for work currently. I'll fix it in a week or so when I get back home. Thanks for reporting.
Thanks! Maybe as a feature suggestion including an option to remove BOM's? The tool I mentioned before is open source, maybe you can use that ?
2014-06-06, 15:32
(2014-06-06, 07:01)Jeroen Wrote: [ -> ](2014-06-05, 18:43)Bumpaneer Wrote: [ -> ]Travelling for work currently. I'll fix it in a week or so when I get back home. Thanks for reporting.
It actually will already with what phil had coded. You have to use the program to "convert" (even if all you do is "modify" spacing) and it will remove the BOMs today.
2014-06-06, 15:36
(2014-06-06, 15:32)Bumpaneer Wrote: [ -> ]It actually will already with what phil had coded. You have to use the program to "convert" (even if all you do is "modify" spacing) and it will remove the BOMs today.
Ah ok, I didn't know that. I usually only use it for the checking. Cheers!
2014-06-11, 19:06
I don't think this has been mentioned.
I have this one (and others like it) in my log:
example usage:
Applies to textboxes and grouplists.
DialogProgress.xml: Invalid Attribute for height: max
example usage:
PHP Code:
<height max="n">auto</height>
2014-06-15, 18:58
(2014-06-04, 14:12)Jeroen Wrote: [ -> ]I'm getting
Quote:Undefined Vars:
window_Title
in my log. I only have a buch of vars named
window_Title.Video
window_Title.Music
window_Title.Pictures
...etc
So I guess it sees the period as end of the var?
It's also mentioning those vars (using the complete names) as unused.
edit: oh and my OCD is forcing me to mention there's a typo on the Texturepacker button (TexutePacker)
(2014-06-11, 19:06)Jeroen Wrote: [ -> ]I don't think this has been mentioned.
Code:DialogProgress.xml: Invalid Attribute for height: max
example usage:
PHP Code:<height max="n">auto</height>
Both of these issues should be fixed now: https://dl.dropboxusercontent.com/u/1681...v1.2.2.exe
Thanks for reporting them.
2014-06-16, 18:42
In 'check values' i'm getting something i think is not right:
Invalid Attribute for animation: reversable
2014-06-16, 20:21
(2014-06-15, 18:58)Bumpaneer Wrote: [ -> ]Both of these issues should be fixed now: https://dl.dropboxusercontent.com/u/1681...v1.2.2.exe
2014-06-16, 23:20
(2014-06-16, 18:42)MassIV Wrote: [ -> ]In 'check values' i'm getting something i think is not right:
Shouldn't it be reversible?
2014-06-17, 00:11
Oops.
Yes, sorry for wasting your time.
2014-06-17, 19:36
Would it be possible to print line numbers on found issues? Makes it easier to find the culprit i think (i'm being forced to use it now )
General question. Is this fully updated for Gotham atm? Need to handle skins during time ronie is unavailable.
2014-06-18, 01:48
(2014-06-17, 19:36)Martijn Wrote: [ -> ]Would it be possible to print line numbers on found issues? Makes it easier to find the culprit i think (i'm being forced to use it now )
(2013-01-28, 00:12)phil65 Wrote: [ -> ]identifying the line numbers is not that easy because i do not parse the xml "as a textfile". will see if i can come up with something.
Looks like phil65 was never able to find a workaround. The xml from the skins is read into the program and parsed like a tree, with each element being a branch. It has no concept of line numbers in its current state.
(2014-06-17, 19:36)Martijn Wrote: [ -> ]General question. Is this fully updated for Gotham atm? Need to handle skins during time ronie is unavailable.
No idea if it is fully updated. That was one of the reasons I offered to help update the code. As people point out problems I can definitely dig into the code to address them, but I'm not aware of all the intricacies of skinning like many of the people posting here are.
2014-06-19, 23:50
Some false reporting by the XML check it seems:
DialogMediaFilter.xml: Invalid Value for //control[@type='button']/*: invalidcolor
“invalidcolor” is a valid Gotham button value (Checked in Confluence/XBMC Code).
According to Nessus this should be valid as well:
“selected” is a valid button value
You can see in his skin code: http://github.com/Nessus85100/Bello
2014-06-20, 02:09
Here are some code examples :
“invalidcolor” value
Bello example : https://github.com/Nessus85100/Bello/blo...ry.xml#L39
Confluence example : https://github.com/xbmc/xbmc/blob/master...y.xml#L213
“selected” value
Bello example : https://github.com/Nessus85100/Bello/blo...s.xml#L144
Confluence example : https://github.com/xbmc/xbmc/blob/master...s.xml#L249
Thanks a lot of your work on this tool.
Cheers
Nessus
“selected” value
Cheers
Nessus
