2012-10-14, 16:36
Pages: 1 2
2015-01-30, 01:17
Sorry to ask, but does this still apply? My language strings need quite some work and could certainly do with input.
Thank you.
Thank you.
2015-01-30, 16:21
sure, pretty much every skin in the repo uses it, so why shouldn't you. ;-)
2015-01-30, 18:18
(2015-01-30, 16:21)ronie Wrote: [ -> ]sure, pretty much every skin in the repo uses it, so why shouldn't you. ;-)
It's not been something high up on my list of to-dos, but really does need to be done. I'll take a look through the post and hopefully get this sorted out so it's FAR easier to use correct strings.
Cheers for the reply
Edit: The reason I asked if it still applied is because it references Frodo in the text
2015-01-30, 18:23
(2015-01-30, 18:18)Piers Wrote: [ -> ][quote='ronie' pid='1909188' dateline='1422627690']and XBMC
2015-01-30, 21:16
Email sent, I think I did it correctly - we'll see
2015-01-31, 01:25
updated first post a bit :-)
2015-01-31, 06:47
(2015-01-31, 01:25)ronie Wrote: [ -> ]updated first post a bit :-)
Makes far more sense now. I remember looking at the first post a month or so ago - I was put off by the wording, I really should have just asked
2015-02-01, 18:13
Is it normal for it to take a few days to get an reply?
2015-02-01, 18:18
(2015-02-01, 18:13)Piers Wrote: [ -> ]Is it normal for it to take a few days to get an reply?
yup, i'm afraid it may even take several weeks.
2015-02-01, 20:02
(2015-02-01, 18:18)ronie Wrote: [ -> ](2015-02-01, 18:13)Piers Wrote: [ -> ]Is it normal for it to take a few days to get an reply?
Ah, I see. I've updated nearly every string in the EN files, I won't send a git pull request until I've managed to sort out all the strings.
Thank you for letting me know
2015-07-07, 21:26
Currently I'm working on the Revolve skin. I would love to get translations for this skin, but after reading this thread I still have several questions:
1. Revolve is currently work in progress. It is not part of the official Kodi repository, and currently it only supports XBMC Gotham (although I plan to upgrade it to Kodi Helix and Isengard after I made a final release for Gotham). Can I get translations for Revolve when it only supports an old version of Kodi and when it is not in the official repository?
2. Revolve still uses a strings.xml file. Do I need to convert my strings.xml file to strings.po, or will Transifex do this?
3. And if Revolve can use the Transifex translation service, how can I get an email on the xbmc-addons mailing list?
Thanks for your help!
2015-07-08, 08:39
1 repo or not doesn't matter.
2 Tansifex will handle it.
3 subscribe to the addon mailing list: http://kodi.wiki/view/Submitting_Add-ons...iling_list
2015-07-08, 11:00
Email sent. Thank you for your reply, ronie!
2015-07-11, 10:41
(2015-07-08, 08:39)ronie Wrote: [ -> ]1 repo or not doesn't matter.
Hopefully not beating a dead horse but I am wondering if there are any issues with it being a strings.po from a mod for a skin that is on the Kodi repo?
Pages: 1 2
