2013-01-27, 09:28
2013-01-27, 14:08
My bad davilla , i'm gonna explain my point in the Frodo section
Nemrod
Nemrod
2013-01-27, 14:13
(2013-01-27, 14:08)Nemrod Wrote: [ -> ]My bad davilla , i'm gonna explain my point in the Frodo section
Nemrod
You can't do it here?
2013-01-27, 14:16
I can but it's another point than the crash on loading on loading.
Nemrod
Nemrod
2013-01-28, 05:56
Soooo, I need to play the shell game and follow you as you jump off to another section in the forum ?
2013-01-28, 11:47
No, as i said to Martijn, i'll post here.
Nemrod
Nemrod
2013-02-08, 22:48
I have somes crashes on startup withe Frodo, here is the OS X LOG.
Next time i'll post the XBMC LOG
Nemrod
Nemrod
2013-02-09, 00:43
try the 32bit version of xbmc and report back.
2013-02-09, 15:35
2013-02-09, 19:00
Move your xbmc Folder under ~/Library/Application Support/XBMC away and see if that makes it going...
2013-02-20, 20:09
(2013-02-09, 19:00)Memphiz Wrote: [ -> ]Move your xbmc Folder under ~/Library/Application Support/XBMC away and see if that makes it going...
Thanks, i'm gonna test tonight.
Edit :
Ok so first point after moving the XBMC folder, i have a brand new XBMC at startup, without any previous settings ....
Nemrod
2013-02-21, 00:46
of course you have. That was expected (thats why i wrote "move away" and not "delete"...)
2013-02-21, 01:46
(2013-02-21, 00:46)Memphiz Wrote: [ -> ]of course you have. That was expected (thats why i wrote "move away" and not "delete"...)
Of course i have ? Well i wrote that because i did no expect it, this illustrates the fact that what is obvious to one is not the other.
So, another question from a noob, does this mean if it work i will have to do all the settings manually ?
Nemrod
2013-02-21, 11:35
I am having trouble lately and XBMC does not load at startup. It crashes and the report is attached. I think it has something to do with the tags of the movies or what xbmc does at startup. What I am trying to say is that it was fine. I updated tags on a movie and no more XBMC. I removed that movie from the movies folder reinstalled xbmc and the same thing.
Please advise at the earliest as I dont have xbmc anymore and my entire media setup is around xbmc.
Crash Log
UPDATE:
Reinstalled xbmc and all is gone but it works. Please let me know the problem and what caused it as this is the 4-5 th time this has happened. I did not care before as I was testing being new to xbmc but now need to finalize the setup and have tagged everything based on xbmc
Crash Log
UPDATE:
2013-02-21, 14:04
@noshali you are crashing on a raw image file somewhere in your movie folders or in your database. Please try the latest nightly build or use the 32bit version of xbmc. One of both should fix your problems.
