2013-02-21, 16:46
2013-02-21, 16:46
2013-02-22, 00:12
(2013-02-21, 01:46)Nemrod Wrote: [ -> ](2013-02-21, 00:46)Memphiz Wrote: [ -> ]of course you have. That was expected (thats why i wrote "move away" and not "delete"...)
Of course i have ? Well i wrote that because i did no expect it, this illustrates the fact that what is obvious to one is not the other.
So, another question from a noob, does this mean if it work i will have to do all the settings manually ?
Nemrod
Is there a way i can avoid manual settings ? Thanks.
Nemrod
2013-02-23, 18:25
(2013-02-22, 00:12)Nemrod Wrote: [ -> ](2013-02-21, 01:46)Nemrod Wrote: [ -> ](2013-02-21, 00:46)Memphiz Wrote: [ -> ]of course you have. That was expected (thats why i wrote "move away" and not "delete"...)
Nemrod
Nemrod
For instance when i moved the folder as discussed i lost my skins.
Nemrod
2013-02-23, 20:03
Then put folder by folder back and see when the problem starts again...
2013-02-23, 20:11
I already did it.
2013-02-24, 23:54
(2013-02-23, 20:11)Nemrod Wrote: [ -> ]I already did it.
I moved back the XBMC folder & i get back a crash on loading.
Nemrod
2013-02-25, 00:15
re-read my post
2013-02-25, 00:22
(2013-02-25, 00:15)Memphiz Wrote: [ -> ]re-read my post
I did.
It might be clear for you but it is not for me so i do whatever i can but i can't guess what you mean.
Nemrod
2013-02-25, 13:36
I didn't state to put the whole folder back at once. Just try it piece by piece.
2013-02-25, 14:09
(2013-02-25, 13:36)Memphiz Wrote: [ -> ]I didn't state to put the whole folder back at once. Just try it piece by piece.
My bad, i'm gonna test tonight.
Nemrod
2013-03-09, 15:28
Nemrod
Nemrod
I found an addon that backup all the addons, so now i'm testing with XBMC folder on : ~/Library/Application Support/.
Nemrod
2013-03-15, 22:51
(2013-03-09, 15:28)Nemrod Wrote: [ -> ]Hi,
Nemrod
I just had my first crash this evening.
Nemrod
2013-03-26, 15:26
I'm still trying to get help solve my problem.
My problem is the following : "I have a lot of crashes when loading XBMC, on OS X 10.8. Here is the OS X log, in don't know if the XBMC has an interest because it's realy few second after clic on the Apple remote.".
First answer/help is :
I indeed use some time screen sharing to manage my Mac Mini from my Macbook Pro but i avoid it while watching a TV show or a movie because it can bring other problems.
Second answer/help :
Ok since then i'm using Frodo, no change.
Third answer/help :
Ok since then i'm using the 32 bit version, no change.
Fourth answer/help :
So right know my XBMC folder is in ~/Library/Application Support/XBMC and i still have some crashes.
Nemrod
(2012-11-17, 14:26)Memphiz Wrote: [ -> ]Known bug - fixed in frodo. Do you have multimonitor setup or something like that?
(2013-01-20, 16:04)Memphiz Wrote: [ -> ]Yeah still eden? We know that this bug is in there? So whats the point?
Third answer/help :
(2013-02-09, 00:43)Memphiz Wrote: [ -> ]try the 32bit version of xbmc and report back.
(2013-02-09, 19:00)Memphiz Wrote: [ -> ]Move your xbmc Folder under ~/Library/Application Support/XBMC away and see if that makes it going...
Nemrod
2013-03-27, 02:00
post a new crashreporter log from frodo to pastebin and put the link in here.
2013-03-27, 03:11
12.1 X64/32 is definitley jacked, the nightly for x64 does not work either. 12.1 32only will work on 10.8.3. my setup is mac client accessing win8 mysql setup.
hope this helps, try the 32bit osx version if you get immediate crashing.
