in library view, i get a lockup when navigating to:
- genres -> all genres -> all artists (lock)
- artists -> all artists (lock)
- albums (lock)
i have only about a total of 1200 mp3's and some wma's all on one smb share.
if you can't reproduce, pleasy tell me, and i'll give you the info you need
i have the same problem. i just put a build on from october 9 and then deleted and completely rebuilt my music library. i get the same locks as you mentioned and also locks on going into songs.
i have about 15,000 songs and somewhere in the range of 800 different artists (i have a lot of compilation albums and whatnot).
i'll be more than happy to dump logs or give someone the entire library file if need be.
thanks,
mike
(vnm @ oct. 10 2005,19:12 Wrote:if you can't reproduce, pleasy tell me, and i'll give you the info you need
how about some
detailed information on your setup, step-by-step on how to replicate, and a full (0) debug log to start with?
vnm,
please post your log. your database is rather small and certainly shouldnt lock up. the problem definately sounds related your albums table. are you able to choose an artist and get an album listing? also, have you tried renaming your database, and creating a new?
joecool,
you're database is just too large so dont enter songs off the root. xbmc just doesnt have enough memory to get the full list of songs out of the sql query and into the directory listing. the upper limit is around 11k songs.
but, it shouldnt lock up. you should've gotten the "no information for this view" error. (atleast, that's what used to happen to me in the past.)
and please confirm that you have the same exact lockups with albums as vnm. post your log regarding this.
Quote:please post your log.
will do when i'm home from work
will also post other details about my setup.
Quote:are you able to choose an artist and get an album listing?
yes. all ways of navigating the library, besides from the ones mentioned, work as a charm.
Quote:also, have you tried renaming your database, and creating a new?
yes (deleted old)
Quote:11-10-2005 17:40:03 notice -----------------------------------------------------------------------
11-10-2005 17:40:03 notice starting xboxmediacenter. built on oct 10 2005
11-10-2005 17:40:03 notice q is mapped to: harddisk0\partition6\apps\xbmc
11-10-2005 17:40:03 notice log file is located: e:\xbmc\logs\xbmc.log
11-10-2005 17:40:03 notice load settings...
11-10-2005 17:40:03 notice loading t:\settings.xml
11-10-2005 17:40:03 info parsing <profiles> tag
11-10-2005 17:40:03 info calibration for 1080i 16:9 1920x1080
11-10-2005 17:40:03 info subtitle yposition:1042 pixelratio:1.000 offsets:(0,0)->(1920,1080) osdyoffset:0
11-10-2005 17:40:03 info gui calibration :(0,0)->(1920,1080)
11-10-2005 17:40:03 info calibration for 720p 16:9 1280x720
11-10-2005 17:40:03 info subtitle yposition:694 pixelratio:1.000 offsets:(0,0)->(1280,720) osdyoffset:0
11-10-2005 17:40:03 info gui calibration :(0,0)->(1280,720)
11-10-2005 17:40:03 info calibration for 480p 4:3 720x480
11-10-2005 17:40:03 info subtitle yposition:432 pixelratio:0.912 offsets:(0,0)->(720,480) osdyoffset:0
11-10-2005 17:40:03 info gui calibration :(0,0)->(720,480)
11-10-2005 17:40:03 info calibration for 480p 16:9 720x480
11-10-2005 17:40:03 info subtitle yposition:463 pixelratio:1.215 offsets:(0,0)->(720,480) osdyoffset:0
11-10-2005 17:40:03 info calibration for ntsc 4:3 720x480
11-10-2005 17:40:03 info calibration for ntsc 16:9 720x480
11-10-2005 17:40:03 info calibration for pal 4:3 720x576
11-10-2005 17:40:03 info subtitle yposition:518 pixelratio:1.094 offsets:(0,0)->(720,576) osdyoffset:0
11-10-2005 17:40:03 info gui calibration :(0,0)->(720,576)
11-10-2005 17:40:03 info calibration for pal 16:9 720x576
11-10-2005 17:40:03 info subtitle yposition:551 pixelratio:1.455 offsets:(18,-4)->(714,580) osdyoffset:0
11-10-2005 17:40:03 info gui calibration :(7,3)->(719,576)
11-10-2005 17:40:03 info calibration for pal60 4:3 720x480
11-10-2005 17:40:03 info calibration for pal60 16:9 720x480
11-10-2005 17:40:03 notice getting hardware information now...
11-10-2005 17:40:03 info using digital output
11-10-2005 17:40:03 info ac3 pass through is enabled
11-10-2005 17:40:03 info dts pass through is enabled
11-10-2005 17:40:03 notice checking resolution 10
11-10-2005 17:40:03 notice av pack: scart
11-10-2005 17:40:03 notice av flags: widescreen,pal60
11-10-2005 17:40:03 notice setting autoresolution mode 7
11-10-2005 17:40:03 notice loading q:\xboxmediacenter.xml
11-10-2005 17:40:03 debug loglevel: 0
11-10-2005 17:40:03 debug maxretry: 3
11-10-2005 17:40:03 debug enableshutdown: 0
11-10-2005 17:40:03 debug protectshares: 1
11-10-2005 17:40:03 debug mastermode: 1
11-10-2005 17:40:03 debug startuplock: 0
11-10-2005 17:40:03 debug lockfilemanager: 0
11-10-2005 17:40:03 debug locksettings: 0
11-10-2005 17:40:03 debug lockhomemedia: 0
11-10-2005 17:40:03 debug debuglevel: 0
11-10-2005 17:40:03 debug repeat: 480
11-10-2005 17:40:03 debug move: 220
11-10-2005 17:40:03 debug repeat: 220
11-10-2005 17:40:03 debug deadzone: 0.100000
11-10-2005 17:40:03 debug icon: 102
11-10-2005 17:40:03 debug icon: 106
11-10-2005 17:40:03 debug icon: 104
11-10-2005 17:40:03 debug icon: 103
11-10-2005 17:40:03 debug icon: 105
11-10-2005 17:40:03 debug icon: 107
11-10-2005 17:40:03 debug icon: 109
11-10-2005 17:40:03 debug icon: 101
11-10-2005 17:40:03 debug default: 0
11-10-2005 17:40:03 debug parsing <myprograms> tag
11-10-2005 17:40:03 debug setting <default> share to : f:\games
11-10-2005 17:40:03 debug share name: spill
11-10-2005 17:40:03 debug share path: f:\games\
11-10-2005 17:40:03 debug share name: programmer
11-10-2005 17:40:03 debug share path: f:\apps\
11-10-2005 17:40:03 debug parsing <pictures> tag
11-10-2005 17:40:03 debug setting <default> share to : smb://vegardb/d$/mine dokumenter/mine bilder/
11-10-2005 17:40:03 debug share name: bilder
11-10-2005 17:40:03 debug share path: smb://vegardb/d$/mine dokumenter/mine bilder/
11-10-2005 17:40:03 debug parsing <files> tag
11-10-2005 17:40:03 debug share name: c:
11-10-2005 17:40:03 debug share path: c:\
11-10-2005 17:40:03 debug share name: e:
11-10-2005 17:40:03 debug share path: e:\
11-10-2005 17:40:03 debug share name: f:
11-10-2005 17:40:03 debug share name: q:
11-10-2005 17:40:03 debug share path: q:\
11-10-2005 17:40:03 debug share name: dvd-spiller
11-10-2005 17:40:03 debug share path: d:\
11-10-2005 17:40:03 debug share name: d på bærbar:
11-10-2005 17:40:03 debug share name: d på pc:
11-10-2005 17:40:03 debug share path: smb://vegard/d$/
11-10-2005 17:40:03 debug share name: e på pc:
11-10-2005 17:40:03 debug share path: smb://vegard/e$/
11-10-2005 17:40:03 debug parsing <music> tag
11-10-2005 17:40:03 debug setting <default> share to : smb://vegardb/d$/mine dokumenter/min musikk/
11-10-2005 17:40:03 debug share name: musikk
11-10-2005 17:40:03 debug share path: smb://vegardb/d$/mine dokumenter/min musikk/
11-10-2005 17:40:03 debug testing path smb://vegardb/d$/mine dokumenter/min musikk/
11-10-2005 17:40:03 debug testing path d:\
11-10-2005 17:40:03 debug parsing <video> tag
11-10-2005 17:40:03 debug setting <default> share to : f:\video
11-10-2005 17:40:03 debug share name: video
11-10-2005 17:40:03 debug share path: f:\video\
11-10-2005 17:40:04 info map drives...
11-10-2005 17:40:04 info map drive c:
11-10-2005 17:40:04 info map drive e:
11-10-2005 17:40:04 info map drive d:
11-10-2005 17:40:04 info map drive f:
11-10-2005 17:40:04 info drives are mapped
11-10-2005 17:40:04 info checking skinpath existance, and existence of keymap.xml:q:\skin...
11-10-2005 17:40:04 notice -----------------------------------------------------------------------
11-10-2005 17:40:04 notice starting xboxmediacenter. built on oct 10 2005
11-10-2005 17:40:04 notice home path q is mapped to: q: (harddisk0\partition6\apps\xbmc)
11-10-2005 17:40:04 notice log file is located: e:\xbmc\logs\xbmc.log
11-10-2005 17:40:04 debug setting resolution 7
11-10-2005 17:40:04 debug we set resolution 7
11-10-2005 17:40:04 debug splash image q:\media\splash.png not found
11-10-2005 17:40:04 info load language file:q:\language\norwegian\strings.xml
11-10-2005 17:40:04 notice loaded q:\system\players\mplayer\iso639-1.xml
11-10-2005 17:40:04 notice loaded q:\system\players\mplayer\iso639-2.xml
11-10-2005 17:40:04 info load keymapping
11-10-2005 17:40:04 info loading q:\keymap.xml
11-10-2005 17:40:04 info checking skin version of: project mayhem iii
11-10-2005 17:40:04 info skin version is: 1.3
11-10-2005 17:40:04 info gui format 720x576 pal 16:9
11-10-2005 17:40:04 info gui screen offset (0,0)
11-10-2005 17:40:04 info install unhandled exception filter
11-10-2005 17:40:04 info creating subdirectories
11-10-2005 17:40:04 info thumbnails folder:e:\xbmc\thumbs
11-10-2005 17:40:04 info shortcuts folder:e:\xbmc\shortcuts
11-10-2005 17:40:04 info albums folder:e:\xbmc\albums
11-10-2005 17:40:04 info recording folder:e:\xbmc\recordings
11-10-2005 17:40:04 info screenshots folder:e:\xbmc\screenshots
11-10-2005 17:40:04 info subtitle folder:e:\xbmc\subtitles
11-10-2005 17:40:04 notice initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
11-10-2005 17:40:04 warning not initializing network, using settings as they are setup by dashboard
11-10-2005 17:40:04 info init network
11-10-2005 17:40:04 info get local ip address:
11-10-2005 17:40:05 info ip adres:192.168.0.5
11-10-2005 17:40:05 notice start timeserver thread
11-10-2005 17:40:05 notice xbfilezilla: starting...
11-10-2005 17:40:05 notice xbfilezilla: started
11-10-2005 17:40:05 notice start led control
11-10-2005 17:40:05 notice dim lcd on playback
11-10-2005 17:40:05 notice checking the date!
11-10-2005 17:40:05 notice - current date is: 11-10-2005
11-10-2005 17:40:05 notice start dvd mediatype detection
11-10-2005 17:40:05 notice initializing playlistplayer
11-10-2005 17:40:05 info lcd not used
11-10-2005 17:40:05 notice start fancontroller
11-10-2005 17:40:05 notice load default skin:[project mayhem iii]
11-10-2005 17:40:05 info load skin from:q:\skin\project mayhem iii
11-10-2005 17:40:05 info delete old skin...
11-10-2005 17:40:05 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
11-10-2005 17:40:05 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
11-10-2005 17:40:05 info skin version is: 1.3
11-10-2005 17:40:05 info load fonts for skin...
11-10-2005 17:40:05 info loading fonts from q:\skin\project mayhem iii\pal16x9\font.xml
11-10-2005 17:40:05 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
11-10-2005 17:40:05 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
11-10-2005 17:40:05 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
11-10-2005 17:40:05 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
11-10-2005 17:40:05 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
11-10-2005 17:40:05 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
11-10-2005 17:40:05 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
11-10-2005 17:40:05 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
11-10-2005 17:40:05 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal-pal.xpr
11-10-2005 17:40:05 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold-pal.xpr
11-10-2005 17:40:05 info load font:fontbl path:q:\skin\project mayhem iii\fonts\common-font12.xpr
11-10-2005 17:40:05 info load new skin...
11-10-2005 17:40:05 info loading skin file: home.xml
11-10-2005 17:40:05 info loading references file: q:\skin\project mayhem iii\pal16x9\references.xml
11-10-2005 17:40:06 info kaiclient: instantiating...
11-10-2005 17:40:06 debug udpclient: creating udp socket...
11-10-2005 17:40:06 debug udpclient: setting broadcast socket option...
11-10-2005 17:40:06 debug udpclient: setting non-blocking socket options...
11-10-2005 17:40:06 debug udpclient: spawning listener thread...
11-10-2005 17:40:06 debug udpclient: ready.
11-10-2005 17:40:06 info kaiclient: ready.
11-10-2005 17:40:06 info loading user windows q:\skin\project mayhem iii\pal16x9\custom*.xml
11-10-2005 17:40:06 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom1.xml
11-10-2005 17:40:06 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom3.xml
11-10-2005 17:40:06 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom4.xml
11-10-2005 17:40:06 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom5.xml
11-10-2005 17:40:06 info initialize new skin...
11-10-2005 17:40:06 info loading skin file: pointer.xml
11-10-2005 17:40:06 info loading skin file: musicoverlay.xml
11-10-2005 17:40:06 info loading skin file: videooverlay.xml
11-10-2005 17:40:06 info loading skin file: dialogvolumebar.xml
11-10-2005 17:40:06 info loading skin file: dialogseekbar.xml
11-10-2005 17:40:06 info loading skin file: dialogkaitoast.xml
11-10-2005 17:40:06 info loading skin file: dialogmutebug.xml
11-10-2005 17:40:06 info skin loaded...
11-10-2005 17:40:06 notice kaiclient: discovering kai engine via udp broadcast.
11-10-2005 17:40:06 info activating window id: 10000
11-10-2005 17:40:06 info removing tempfiles
11-10-2005 17:40:06 notice initialize done
11-10-2005 17:40:06 notice running the application...
11-10-2005 17:40:06 debug freevisualisation() started
11-10-2005 17:40:06 debug freevisualisation() done
11-10-2005 17:40:08 debug udpclient: listening.
11-10-2005 17:40:08 debug udpclient tx: 6857 -> 'kai_client_discover;'
11-10-2005 17:40:29 debug freevisualisation() started
11-10-2005 17:40:29 debug freevisualisation() done
11-10-2005 17:40:29 info activating window id: 10502
11-10-2005 17:40:29 info loading skin file: mymusicnav.xml
11-10-2005 17:40:29 debug cguiwindowmusicnav::getdirectory(db://)
11-10-2005 17:40:29 debug m_istate = [0], m_ipath = [0]
11-10-2005 17:40:29 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
11-10-2005 17:40:31 debug cguiwindowmusicnav::getdirectory(db://sjanger/)
11-10-2005 17:40:31 debug m_istate = [8], m_ipath = [8]
11-10-2005 17:40:31 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
11-10-2005 17:40:31 debug loading database directory [db://sjanger/]
11-10-2005 17:40:31 debug cmusicdatabase::getgenresnav() query: select strgenre from genre where (idgenre in (select distinct song.idgenre from song) or idgenre in (select distinct exgenresong.idgenre from exgenresong))
11-10-2005 17:40:31 debug caching database directory [db://sjanger/]
11-10-2005 17:40:31 debug -- items: 22, sort method: 0, ascending: 1, skipthe: 1
11-10-2005 17:40:32 debug cguiwindowmusicnav::getdirectory(db://sjanger/* alle sjangre/)
11-10-2005 17:40:32 debug m_istate = [4], m_ipath = [12]
11-10-2005 17:40:32 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
11-10-2005 17:40:32 debug loading database directory [db://sjanger/* alle sjangre/]
11-10-2005 17:40:32 debug cmusicdatabase::getartistsnav() query: select strartist from artist where (idartist in (select distinct song.idartist from song) or idartist in (select distinct exartistsong.idartist from exartistsong)) and artist.idartist<>71
11-10-2005 17:40:32 debug caching database directory [db://sjanger/* alle sjangre/]
11-10-2005 17:40:32 debug -- items: 613, sort method: 8, ascending: 1, skipthe: 1
11-10-2005 17:40:33 debug cguiwindowmusicnav::getdirectory(db://sjanger/* alle sjangre/* alle artister/)
11-10-2005 17:40:33 debug m_istate = [2], m_ipath = [14]
11-10-2005 17:40:33 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
11-10-2005 17:40:33 debug loading database directory [db://sjanger/* alle sjangre/* alle artister/]
11-10-2005 17:40:33 debug cmusicdatabase::getalbumsnav() query: select * from albumview
11-10-2005 17:40:34 debug caching database directory [db://sjanger/* alle sjangre/* alle artister/]
11-10-2005 17:40:34 debug -- items: 209, sort method: 6, ascending: 1, skipthe: 1
11-10-2005 17:40:34 error exception in capplication::render()
11-10-2005 17:40:34 error capplication::render(), too many exceptions
11-10-2005 17:40:34 fatal exception_access_violation (0xc0000005)
at 0x001cf745
i guess you can read all relevant information out of the log.
built using latest xbmctk, latest addition to the changelog being:
Quote: - 10-10-2005 changed: how my music files keeps its path history. this should correct naviagtion issues with overlapping bookmarks, and bookmarks which can traverse into the playlists location.
this changes how <default> path and activatewindow with a dest path work. they are now behave as a virtual bookmark so back from there will display the root bookmark listing.
the setup is excactly the same as it was before the problems appeared.
@ gamester17: is there any other way i can explain how to reproduce it, other than what i did in my first post? of so, tell me, and i'll see what i can do
ot: and btw guys, i love xbmc and i really appreciate you for making it what it is.
ok there there's some uncaptured exception in the library window. possibly related to the cacheing. the query returned 209 items, and it bombed after caching it to disc.
oh, and that line from the changelong only affects music files view, nothing else.
you've done enough to explain how to reproduce it. you're really doing nothing more than entering albums off the root.
** edit... i've been unable to reproduce any issues with the albums listing, and i've got over 700 albums in my database.
i'll compile yet a new build, and do a clean install of it (delete old settings and db). i'll report back later
done. same problem. what to do?
did you remove or rename your database and rescan? if not, please do so. (i recommend just renaming it so you have the old one as a backup.)
here's my debug log. i did this:
1) turn it on
2) go to my music
3) change from files to library view
4) click on albums and it never came back.
Quote:13-10-2005 10:07:32 notice -----------------------------------------------------------------------
13-10-2005 10:07:32 notice new home path! q is mapped to: harddisk0\partition1\apps\xbmc
13-10-2005 10:07:32 notice starting xboxmediacenter. built on oct 9 2005
13-10-2005 10:07:32 notice home path q is mapped to: e:\apps\xbmc (harddisk0\partition1\apps\xbmc)
13-10-2005 10:07:32 notice log file is located: q:\xbmc.log
13-10-2005 10:07:32 debug setting resolution 4
13-10-2005 10:07:32 debug we set resolution 4
13-10-2005 10:07:33 debug we set resolution 4
13-10-2005 10:07:33 info load language file:q:\language\english\strings.xml
13-10-2005 10:07:33 notice loaded q:\system\players\mplayer\iso639-1.xml
13-10-2005 10:07:33 notice loaded q:\system\players\mplayer\iso639-2.xml
13-10-2005 10:07:33 info load keymapping
13-10-2005 10:07:33 info loading q:\keymap.xml
13-10-2005 10:07:33 info checking skin version of: project mayhem iii
13-10-2005 10:07:33 info skin version is: 1.3
13-10-2005 10:07:33 info gui format 720x480 ntsc 4:3
13-10-2005 10:07:33 info gui screen offset (0,0)
13-10-2005 10:07:33 info install unhandled exception filter
13-10-2005 10:07:33 info creating subdirectories
13-10-2005 10:07:33 info thumbnails folder:q:\thumbs
13-10-2005 10:07:33 info shortcuts folder:q:\shortcuts
13-10-2005 10:07:33 info albums folder:q:\albums
13-10-2005 10:07:33 info recording folder:q:\recordings
13-10-2005 10:07:33 info screenshots folder:q:\screenshots
13-10-2005 10:07:33 info subtitle folder:q:\subtitles
13-10-2005 10:07:33 notice initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
13-10-2005 10:07:33 warning not initializing network, using settings as they are setup by dashboard
13-10-2005 10:07:33 info init network
13-10-2005 10:07:33 info get local ip address:
13-10-2005 10:07:34 info ip adres:10.1.1.253
13-10-2005 10:07:34 notice start timeserver thread
13-10-2005 10:07:34 notice xbfilezilla: starting...
13-10-2005 10:07:34 notice xbfilezilla: started
13-10-2005 10:07:34 notice start led control
13-10-2005 10:07:34 notice dim lcd on playback
13-10-2005 10:07:34 notice checking the date!
13-10-2005 10:07:34 notice - current date is: 13-10-2005
13-10-2005 10:07:34 notice start dvd mediatype detection
13-10-2005 10:07:34 notice initializing playlistplayer
13-10-2005 10:07:34 info lcd not used
13-10-2005 10:07:34 notice start fancontroller
13-10-2005 10:07:34 notice load default skin:[project mayhem iii]
13-10-2005 10:07:34 info load skin from:q:\skin\project mayhem iii
13-10-2005 10:07:34 info delete old skin...
13-10-2005 10:07:34 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
13-10-2005 10:07:34 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
13-10-2005 10:07:34 info skin version is: 1.3
13-10-2005 10:07:34 info load fonts for skin...
13-10-2005 10:07:34 info loading fonts from q:\skin\project mayhem iii\ntsc\font.xml
13-10-2005 10:07:34 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
13-10-2005 10:07:36 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
13-10-2005 10:07:36 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
13-10-2005 10:07:36 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
13-10-2005 10:07:36 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
13-10-2005 10:07:36 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:07:36 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
13-10-2005 10:07:36 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:07:36 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal.xpr
13-10-2005 10:07:36 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold.xpr
13-10-2005 10:07:36 info load font:fontbl path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:07:36 info load new skin...
13-10-2005 10:07:36 info skin version is: 1.3
13-10-2005 10:07:36 info loading skin file: home.xml
13-10-2005 10:07:36 info loading references file: q:\skin\project mayhem iii\ntsc\references.xml
13-10-2005 10:07:36 info kaiclient: instantiating...
13-10-2005 10:07:36 debug udpclient: creating udp socket...
13-10-2005 10:07:36 debug udpclient: setting broadcast socket option...
13-10-2005 10:07:36 debug udpclient: setting non-blocking socket options...
13-10-2005 10:07:36 debug udpclient: spawning listener thread...
13-10-2005 10:07:36 debug udpclient: ready.
13-10-2005 10:07:36 info kaiclient: ready.
13-10-2005 10:07:36 info loading user windows q:\skin\project mayhem iii\pal\custom*.xml
13-10-2005 10:07:36 info loading skin file: q:\skin\project mayhem iii\pal\custom1.xml
13-10-2005 10:07:36 info loading skin file: q:\skin\project mayhem iii\pal\custom3.xml
13-10-2005 10:07:36 info loading skin file: q:\skin\project mayhem iii\pal\custom4.xml
13-10-2005 10:07:36 info loading skin file: q:\skin\project mayhem iii\pal\custom5.xml
13-10-2005 10:07:36 info initialize new skin...
13-10-2005 10:07:36 info loading skin file: pointer.xml
13-10-2005 10:07:36 info loading skin file: musicoverlay.xml
13-10-2005 10:07:36 info loading skin file: videooverlay.xml
13-10-2005 10:07:36 info loading skin file: dialogvolumebar.xml
13-10-2005 10:07:36 info loading skin file: dialogseekbar.xml
13-10-2005 10:07:36 info loading skin file: dialogkaitoast.xml
13-10-2005 10:07:36 info loading skin file: dialogmutebug.xml
13-10-2005 10:07:36 info loading q:\skin\project mayhem iii\sounds\sounds.xml
13-10-2005 10:07:36 info skin loaded...
13-10-2005 10:07:36 notice kaiclient: attach to kai engine host at 10.1.1.100
13-10-2005 10:07:36 info activating window id: 10000
13-10-2005 10:07:36 info removing tempfiles
13-10-2005 10:07:36 notice initialize done
13-10-2005 10:07:36 notice running the application...
13-10-2005 10:07:36 debug loadlibrarya('zlib.pyd')
13-10-2005 10:07:36 warning kernel32.dll fake function disablethreadlibrarycalls called
13-10-2005 10:07:36 debug loadlibrary('zlib.pyd') returning: 0x839ab0
13-10-2005 10:07:36 debug zlib.pyd!getprocaddress(0x839ab0, 'initzlib') => 0x992210
13-10-2005 10:07:37 info -->python initialized<--
13-10-2005 10:07:38 debug udpclient: listening.
13-10-2005 10:07:38 debug udpclient tx: 19641 -> 'kai_client_attach;'
13-10-2005 10:07:39 debug freevisualisation() started
13-10-2005 10:07:39 debug freevisualisation() done
13-10-2005 10:07:39 info activating window id: 10501
13-10-2005 10:07:39 info attempting to default to:
13-10-2005 10:07:39 info loading skin file: mymusicsongs.xml
13-10-2005 10:07:43 info activating window id: 10502
13-10-2005 10:07:43 info loading skin file: mymusicnav.xml
13-10-2005 10:07:43 debug cguiwindowmusicnav::getdirectory(db://)
13-10-2005 10:07:43 debug m_istate = [0], m_ipath = [0]
13-10-2005 10:07:43 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:07:45 debug cguiwindowmusicnav::getdirectory(db://artists/)
13-10-2005 10:07:45 debug m_istate = [4], m_ipath = [4]
13-10-2005 10:07:45 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:07:45 debug loading database directory [db://artists/]
13-10-2005 10:07:45 debug cmusicdatabase::getartistsnav() query: select strartist from artist where (idartist in (select distinct song.idartist from song) or idartist in (select distinct exartistsong.idartist from exartistsong)) and artist.idartist<>22
13-10-2005 10:07:47 debug caching database directory [db://artists/]
13-10-2005 10:07:47 debug -- items: 2614, sort method: 8, ascending: 1, skipthe: 1
13-10-2005 10:07:47 error exception in capplication::render()
i did the same thing except went into genres->all genres:
Quote:13-10-2005 10:12:58 notice -----------------------------------------------------------------------
13-10-2005 10:12:58 notice new home path! q is mapped to: harddisk0\partition1\apps\xbmc
13-10-2005 10:12:58 notice starting xboxmediacenter. built on oct 9 2005
13-10-2005 10:12:58 notice home path q is mapped to: e:\apps\xbmc (harddisk0\partition1\apps\xbmc)
13-10-2005 10:12:58 notice log file is located: q:\xbmc.log
13-10-2005 10:12:58 debug setting resolution 4
13-10-2005 10:12:58 debug we set resolution 4
13-10-2005 10:12:59 debug we set resolution 4
13-10-2005 10:12:59 info load language file:q:\language\english\strings.xml
13-10-2005 10:12:59 notice loaded q:\system\players\mplayer\iso639-1.xml
13-10-2005 10:12:59 notice loaded q:\system\players\mplayer\iso639-2.xml
13-10-2005 10:12:59 info load keymapping
13-10-2005 10:12:59 info loading q:\keymap.xml
13-10-2005 10:12:59 info checking skin version of: project mayhem iii
13-10-2005 10:12:59 info skin version is: 1.3
13-10-2005 10:12:59 info gui format 720x480 ntsc 4:3
13-10-2005 10:12:59 info gui screen offset (0,0)
13-10-2005 10:12:59 info install unhandled exception filter
13-10-2005 10:12:59 info creating subdirectories
13-10-2005 10:12:59 info thumbnails folder:q:\thumbs
13-10-2005 10:12:59 info shortcuts folder:q:\shortcuts
13-10-2005 10:12:59 info albums folder:q:\albums
13-10-2005 10:12:59 info recording folder:q:\recordings
13-10-2005 10:12:59 info screenshots folder:q:\screenshots
13-10-2005 10:12:59 info subtitle folder:q:\subtitles
13-10-2005 10:12:59 notice initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
13-10-2005 10:12:59 warning not initializing network, using settings as they are setup by dashboard
13-10-2005 10:12:59 info init network
13-10-2005 10:12:59 info get local ip address:
13-10-2005 10:13:00 info ip adres:10.1.1.253
13-10-2005 10:13:00 notice start timeserver thread
13-10-2005 10:13:00 notice xbfilezilla: starting...
13-10-2005 10:13:00 notice xbfilezilla: started
13-10-2005 10:13:00 notice start led control
13-10-2005 10:13:00 notice dim lcd on playback
13-10-2005 10:13:00 notice checking the date!
13-10-2005 10:13:00 notice - current date is: 13-10-2005
13-10-2005 10:13:00 notice start dvd mediatype detection
13-10-2005 10:13:00 notice initializing playlistplayer
13-10-2005 10:13:00 info lcd not used
13-10-2005 10:13:00 notice start fancontroller
13-10-2005 10:13:00 notice load default skin:[project mayhem iii]
13-10-2005 10:13:00 info load skin from:q:\skin\project mayhem iii
13-10-2005 10:13:00 info delete old skin...
13-10-2005 10:13:00 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
13-10-2005 10:13:00 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
13-10-2005 10:13:00 info skin version is: 1.3
13-10-2005 10:13:00 info load fonts for skin...
13-10-2005 10:13:00 info loading fonts from q:\skin\project mayhem iii\ntsc\font.xml
13-10-2005 10:13:00 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
13-10-2005 10:13:00 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
13-10-2005 10:13:00 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
13-10-2005 10:13:00 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
13-10-2005 10:13:00 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
13-10-2005 10:13:00 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:13:00 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
13-10-2005 10:13:00 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:13:00 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal.xpr
13-10-2005 10:13:00 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold.xpr
13-10-2005 10:13:00 info load font:fontbl path:q:\skin\project mayhem iii\fonts\common-font10.xpr
13-10-2005 10:13:00 info load new skin...
13-10-2005 10:13:00 info loading skin file: home.xml
13-10-2005 10:13:00 info loading references file: q:\skin\project mayhem iii\ntsc\references.xml
13-10-2005 10:13:00 info kaiclient: instantiating...
13-10-2005 10:13:00 debug udpclient: creating udp socket...
13-10-2005 10:13:00 debug udpclient: setting broadcast socket option...
13-10-2005 10:13:00 debug udpclient: setting non-blocking socket options...
13-10-2005 10:13:00 debug udpclient: spawning listener thread...
13-10-2005 10:13:00 debug udpclient: ready.
13-10-2005 10:13:00 info kaiclient: ready.
13-10-2005 10:13:00 info loading user windows q:\skin\project mayhem iii\pal\custom*.xml
13-10-2005 10:13:00 info loading skin file: q:\skin\project mayhem iii\pal\custom1.xml
13-10-2005 10:13:00 info loading skin file: q:\skin\project mayhem iii\pal\custom3.xml
13-10-2005 10:13:00 info loading skin file: q:\skin\project mayhem iii\pal\custom4.xml
13-10-2005 10:13:00 info loading skin file: q:\skin\project mayhem iii\pal\custom5.xml
13-10-2005 10:13:00 info initialize new skin...
13-10-2005 10:13:00 info loading skin file: pointer.xml
13-10-2005 10:13:00 info loading skin file: musicoverlay.xml
13-10-2005 10:13:00 info loading skin file: videooverlay.xml
13-10-2005 10:13:00 info loading skin file: dialogvolumebar.xml
13-10-2005 10:13:00 info loading skin file: dialogseekbar.xml
13-10-2005 10:13:00 info loading skin file: dialogkaitoast.xml
13-10-2005 10:13:00 info loading skin file: dialogmutebug.xml
13-10-2005 10:13:00 info loading q:\skin\project mayhem iii\sounds\sounds.xml
13-10-2005 10:13:00 info skin loaded...
13-10-2005 10:13:00 notice kaiclient: attach to kai engine host at 10.1.1.100
13-10-2005 10:13:00 info activating window id: 10000
13-10-2005 10:13:00 info removing tempfiles
13-10-2005 10:13:00 notice initialize done
13-10-2005 10:13:00 notice running the application...
13-10-2005 10:13:00 debug loadlibrarya('zlib.pyd')
13-10-2005 10:13:00 warning kernel32.dll fake function disablethreadlibrarycalls called
13-10-2005 10:13:00 debug loadlibrary('zlib.pyd') returning: 0x839ab0
13-10-2005 10:13:00 debug zlib.pyd!getprocaddress(0x839ab0, 'initzlib') => 0x992210
13-10-2005 10:13:00 info -->python initialized<--
13-10-2005 10:13:02 debug udpclient: listening.
13-10-2005 10:13:02 debug udpclient tx: 19532 -> 'kai_client_attach;'
13-10-2005 10:13:03 debug freevisualisation() started
13-10-2005 10:13:03 debug freevisualisation() done
13-10-2005 10:13:03 info activating window id: 10502
13-10-2005 10:13:03 info loading skin file: mymusicnav.xml
13-10-2005 10:13:03 debug cguiwindowmusicnav::getdirectory(db://)
13-10-2005 10:13:03 debug m_istate = [0], m_ipath = [0]
13-10-2005 10:13:03 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:13:05 debug cguiwindowmusicnav::getdirectory(db://genres/)
13-10-2005 10:13:05 debug m_istate = [8], m_ipath = [8]
13-10-2005 10:13:05 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:13:05 debug loading database directory [db://genres/]
13-10-2005 10:13:05 debug cmusicdatabase::getgenresnav() query: select strgenre from genre where (idgenre in (select distinct song.idgenre from song) or idgenre in (select distinct exgenresong.idgenre from exgenresong))
13-10-2005 10:13:06 debug caching database directory [db://genres/]
13-10-2005 10:13:06 debug -- items: 36, sort method: 0, ascending: 1, skipthe: 1
13-10-2005 10:13:11 info activating window id: 10000
13-10-2005 10:13:11 info loading skin file: home.xml
13-10-2005 10:14:03 debug freevisualisation() started
13-10-2005 10:14:03 debug freevisualisation() done
13-10-2005 10:14:03 info activating window id: 10502
13-10-2005 10:14:03 info loading skin file: mymusicnav.xml
13-10-2005 10:14:03 debug cguiwindowmusicnav::getdirectory(db://genres/)
13-10-2005 10:14:03 debug m_istate = [8], m_ipath = [8]
13-10-2005 10:14:03 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:14:03 debug loading database directory [db://genres/]
13-10-2005 10:14:03 debug -- items: 36, sort method: 0, ascending: 1, skipthe: 1
13-10-2005 10:14:07 debug cguiwindowmusicnav::getdirectory(db://genres/* all genres/)
13-10-2005 10:14:07 debug m_istate = [4], m_ipath = [12]
13-10-2005 10:14:07 debug strgenre = [], strartist = [], stralbum = [], stralbumpath = []
13-10-2005 10:14:07 debug loading database directory [db://genres/* all genres/]
13-10-2005 10:14:07 debug cmusicdatabase::getartistsnav() query: select strartist from artist where (idartist in (select distinct song.idartist from song) or idartist in (select distinct exartistsong.idartist from exartistsong)) and artist.idartist<>22
13-10-2005 10:14:09 debug caching database directory [db://genres/* all genres/]
13-10-2005 10:14:09 debug -- items: 2614, sort method: 8, ascending: 1, skipthe: 1
13-10-2005 10:14:09 error exception in capplication::render()
also, i never got the "no information for this view" error you refered to while i was looking at the library. one thing that might be relevant is that every single song in my library is on a smb share - maybe smb is the problem? anything else i can provide?
thanks,
mike
joecool
does everything in your library lock up, or just artists? (according to your log, you did not click on albums, you clicked on artists.) and genres->all genres is the same as entering artists.
its definately not smb. my entire music collection is over smb, across four different bookmark locations, and its nearly 10,000 songs.
the "no scanned information" error only comes up when the sql query fails to return anything. in both your cases, the sql query is definately returning data. here's it in your log:
Quote:13-10-2005 10:07:47 debug caching database directory [db://artists/]
if you get this message, then the sql query definately returned. in fact, it returned 2,614 unique artists, which were converted into window items. xbmc then cached these items to disc for speed.
i'd have to go back and look at the code to see where it caches. but, have you guys changed your cache location in xboxmediacenter.xml?
and i'll ask you to do the same as vnm. please rename your database and rescan. report if the problem persists with a brand new database. also, try to do this test with the latest cvs version.
(kraqh3d @ oct. 13 2005,16:19 Wrote:did you remove or rename your database and rescan?
i did what i said i'd do
i've now sent you a copy of my db. hope it helps!
edit: my email was rejected. ("remote host said: 552 5.7.0 illegal attachment...") i'll try to get it to you another way...
i just tried and albums works fine. so for me i guess it's just artists that's causing the thing to fail. (and songs but that's because i have so many so no biggie).
Quote:its definately not smb. my entire music collection is over smb, across four different bookmark locations, and its nearly 10,000 songs.
i never noticed this until i recently moved everything into a single folder on a single share. so my /mp3 share on the server has this structure:
/mp3
/artist 1
/album 1
/album 2
/artist 2
/album 3
i guess it's worth noting that i have such a large number of entries in the root directory list.
Quote:but, have you guys changed your cache location in xboxmediacenter.xml?
i have not.
Quote:and i'll ask you to do the same as vnm. please rename your database and rescan. report if the problem persists with a brand new database. also, try to do this test with the latest cvs version.
i did this the other day to see if it would help and the same thing happened.
anything else i can do?
