Add-on unofficlally updated by me to work with latest Kodi 20, will also work with Kodi 19.
(File updated with some SQL modifications)
(2022-09-02, 19:18)HeresJohnny Wrote: [ -> ]Add-on unofficlally updated by me to work with latest Kodi 20, will also work with Kodi 19.
Does that include the UserRating mod by axbmcuser?
axbmcuser do you still have available the UserRating mod for v19? I tried the links but no longer working.
I've only updated (with a download-link in the respective thread) those add-ons which I use myself and which threw errors in v20.
(2022-09-18, 01:25)Karellen Wrote: [ -> ]Does that include the UserRating mod by axbmcuser?
I see now what you mean. We tried to troubleshoot the mod errors in
#482 - #487 but it didn't work for me so I uninstalled and forgot about it. I tried again now to edit it but failed at least for my setup since there seems to be a problem specific to SQLite vs. MySQL which is beyond the scope of my meager abilities. You can still try if
THIS works for you. I found another user rating add-on in my files which I have no idea what it does exactly but I
edited it blindly to work with Kodi N (at least it throws no obvious errors). Maybe that is somehow useful to you.
HeresJohnny
I've already fixed my issue with some SQL fiddling. I had a particular source I needed to rescrape to fix a blunder of mine, but wanted to keep my user ratings and other info intact.
I'll have a look at that script.userrating.
I've just installed this addon and upon running it for the first time, I get a lot of messages about TV shows that don't have a tvdb id and therefore cannot be added to the database.
The advice is to do a rescrape and although that works (tried it with a few shows), this also loses the already existing watched status of the episodes from the rescraped show.
Is there a way to add the correct tvdb id to an existing show without rescraping? All my databases are in MySQL and I don't mind tinkering with them. But I could not find where the tvdb id is currently stored in the Kodi MyVideos database.
The issue and some suggested solutions have been treated here already. I suggest you read a few pages back.
Thank you to everyone that has kept this addon going. It is extremely useful when Database issue arrise and it has to be rebuilt.
One question I have is: Can the info pop-up be disabled? It tends to always appear while watching something. I have the progress dialogue turned off in the settings, but the info pop-up still shows up after the add-on has run.
(2022-09-18, 01:25)Karellen Wrote: [ -> ]@axbmcuser do you still have available the UserRating mod for v19? I tried the links but no longer working.
Sorry for the late reply. Life got in the way.
I have not looked into my userrating mod of this addon in months and would have to refresh my memory about it.
I think you may already found the download, but to be sure, here is the link for the latest (old) downloads of service.watchedlist-XXX_userrating_mod:
https://forum.kodi.tv/showthread.php?tid...pid3094795
Disclaimer:
As far as i remember (99,8%), the mod can't just be used with existing data from a unmodified addon.
Always start clean. There is no compatibility when switching between unmodified/modified addon versions, neither backwards, nor forwards.
Good Day
I am on Kodi 20 Beta 1 for CoreElec and used 20.service.watchedlist.zip to overwrite the add-on that i have now. I created a blank DB called WatchedList.
Is this version going to be the official fix for this ?
What part of "Add-on unofficially updated by me" prompted you to pose this question?
(2022-12-10, 09:58)HeresJohnny Wrote: [ -> ]What part of "Add-on unofficially updated by me" prompted you to pose this question?
It was a Simple Question since this has been broken for months. Do you plan to make it official ?
HeresJohnny is not the add-on's developer, so he can't make it official.
For now just use which version of the add-on that works best for you that other users are kind enough to modify and post.
Thanks. How do i go about fixing an DB that was used on the old version that has SQL issues please
Do i just copy over the add-on and then let it run or must i create a new DB and then how do i import it?
Are you referring to post #504 ? If so, then you're probably out of luck since that concerns a mod of this add-on. If you just have SQL errors in general and have your database in SQLite format, this add-on is only useful if it syncs two installations of Kodi. Just copy the good database over the one with errors (while Kodi is not running).
