2013-10-05, 18:01
(2013-10-05, 13:56)TheImmortal Wrote: [ -> ]WMC displays thumbnails for common shows/movies in it's EPG. Is this data transferable to the PVR client in a similar fashion to the channel icons?
Interesting. The wmc database specifies the show icons through internet addresses. Here is an example one from my wmc database:
e.Program.GuideImage.ImageUrl = "http://images.windowsmedia.com/tvcards/org/2633_19.jpg"
I just pass this url onto the clients and that has been working for me. It seems like the only way it could fail is if your raspbmc does not have an internet connection - or xbmc is not allowed to use the connection. Is that the problem?
To answer your question though, yes, I could cache the guide icons the same way I do channel icons, if for some reason the url's don't work - but I wonder why they don't work. Please let me know.
(2013-10-05, 16:29)hoopsdavis Wrote: [ -> ](2013-10-05, 14:47)edgedamage Wrote: [ -> ]Working great here with, RASPBMC & WIN7. Only one little minor problem, the recordings folder never populates with recorded shows. Even after a successful recording, ServerWMC even shows Recordings: 0. I am able to manually browse to the "Recorded TV" folder on the win7 box with RASPBMC. and play the recorded shows.
Sounds like you don't have the correct folder being watched.
Have you changed your recorded TV folder?
Are you able to see the recordings on the main server PC from within xbmc?
Do you have the correct networked recorded TV folder listed in serverWMC (folders tab)
Also, if you have credentials enabled in serverWMC (folders tab) disable, restart serverWMC and try again.
Hoops advice is excellent, with one quibble: for the raspbmc client credentials need to be enabled with the correct info (unless you set up the credentials with path substitution in xbmc's config).
Also, make sure you aren't 'watching' any other other folders for recorded tv in your wmc settings except for the main recorded folder.
