I pushed version 0.9.2 to github. If you use the ZIP download from github keep in mind that you might haver to remove the "-master" portion from the directory as mentioned by bass63.
@NCKYTUN: This version should fix your issue.
Since throwing a full scene release file name at subscene seems to give very mixed results, I try some heuristics first to determine if its a movie (i.e. it has a year in its filename) or a TV show (it has an episode code) before just doing a file name search.
Thanks so much CrowleyAJ and amet!!! it works perfect.
Glad to hear. I'll send it to the official repo then
crowley sorry about the delay t report , it work perfect i using it as default , thanks
Hello, since the last update I made I'm getting an Unicode/decode error in script when downloading a sub (wherever the sub file is) with subscene service. Logs are available in
http://sprunge.us/fKRZ (last error is related to podnapisi but the previous one is subscene). Any hints ?
Hi nard,
thanks for your report. I had a look at it, but unfortunately I'm not sure, what to do about it. The problem occurs inside a Python library, when cleaning up the temp directory before extracting new files and there seems to be an encoding problem in a filename. Maybe someone reads this, who is bit more proficient in Python and XBMC add-on development and can give me a hint, how to solve this problem.
The error message is this:
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128)
File "/storage/.xbmc/addons/service.subtitles.subscene/service.py", line 422, in <module>
subs = download(params["link"])
File "/storage/.xbmc/addons/service.subtitles.subscene/service.py", line 294, in download
shutil.rmtree(__temp__)
File "/home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-4.0.0/Python-2.7.3/.install_pkg/usr/lib/python2.7/shutil.py", line 239, in rmtree
File "/home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-4.0.0/Python-2.7.3/.install_pkg/usr/lib/python2.7/posixpath.py", line 71, in join
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128)
And it occurs while just calling "shutil.rmtree(__temp__)". Has anyone an idea?
Perhaps I could clean the temp manually if remains there a file with some encoding error in it.
Where is this temp dir ? is it the .xbmc/temp (in that case it's already empty) ?
that would be .xbmc/userdata/addon_data/service.subtitles.subscene/temp/
There was an srt file probably corrupted there, I removed it manually and now it works. Thanks for your help !
When executing a subtitle search as soon as the video starts playing/loading on my raspberry, the addon causes an exception. Allowing the video to fully buffer and run a few seconds does not produce the exception. See below
18:28:09 T:2640110656 ERROR: EXCEPTION: XBMC is not playing any file
18:28:10 T:2640110656 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: XBMC is not playing any file
File "/home/pi/.xbmc/addons/service.subtitles.subscene/service.py", line 387, in <module>
item['file_original_path'] = urllib.unquote(xbmc.Player().getPlayingFile().decode('utf-8')) # Full path
RuntimeError: XBMC is not playing any file
18:28:10 T:2631722048 ERROR: GetDirectory - Error getting plugin://service.subtitles.subscene/?action=search&languages=English
I'm using raspbmc running v13 of xbmc on a raspberry pi
(2014-05-12, 00:18)CrowleyAJ Wrote: [ -> ]Hi nard,
In latest OpenElec Release I'm having this kind of error. Usually is because of corrupt subtitle files in the temp folder of subtitle addon?
How that relates to change this:
__temp__ = xbmc.translatePath( os.path.join( __profile__, 'temp') ).decode("utf-8")
to
and start working all the times?
That sounds wrong. A lot of addons use
so i see no reason why that doesn't work. That line is exactly the reason a lot of addon DO work.
(2014-06-03, 11:13)Martijn Wrote: [ -> ]That sounds wrong. A lot of addons use
So is more probable that is because some corrupt file in the temp folder?
Isn't there a way of prior to download files to the temp folder the addon delete any file on the folder?
I think I made a dumb question, because the problem is right with the code that tries to delete the temp folder with a corrupt file? And has to be treated manually?
So by the code:
__temp__ = xbmc.translatePath(pjoin(__profile__, 'temp')).decode("utf-8")
Is telling that variable __temp_ has the path to temp directory decoded to utf-8 and then:
"""Called when subtitle download request from XBMC."""
# Cleanup temp dir, we recomend you download/unzip your subs in temp folder and
# pass that to XBMC to copy and activate
if xbmcvfs.exists(__temp__):
xbmcvfs.mkdirs(__temp__)
The problem relies on shutil.rmtree(__temp__)
if folder is decoded I get the error, but if is not encoded I don't have, what relates with having a problem with a corrupt file?
To delete folder and every files shouldn't be the same?
hi some day ago, i see problem with subscene, not working, always return not found.
My device is a iPad mini retina running iOS 7.0.4. Please help me. Thanks
