2014-10-04, 00:19
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
2014-10-04, 13:22
failed to download subtitle error
2014-10-04, 23:07
Subscene only search for English subtitles... What happened?
2014-10-22, 03:10
so is there anybody still maintain the subscene plugin
cause it still dosent work...
2014-10-27, 12:55
It downloads new subtitles for me but display some old subtitles...
Using Kodi nightlies.
2014-10-27, 14:54
Hello all,
I'm sorry about the lack of responses in the last weeks. I haven't abandoned the plugin, I just didn't receive any notifications about your posts, so I didn't check the thread.
I will look into your issues ASAP.
2014-10-28, 02:17
Ok, I just tried some movies and TV shows and everything seems ok to me. It returned the right subtitles even in the chosen languages (where available).
So it might be that you ran into some special cases, which failed for some reason. To iron these out I need to know what you did exactly, so I can reproduce these cases. A debug log, as mentioned in the original post, would be most helpful: http://wiki.xbmc.org/index.php?title=Log_file
I tested on XBMC 13.2 Gotham, I will look into Kodi beta later.
2014-10-31, 21:13
I think its probably just a compatible issue but in case its not i explain my problem.
i just removed and uninstall subscen, both in XBMC and manually. and reinstalled and downloaded a pair of subtitles for tvshow 1. i then went in and saw another tvshow and downloaded subtitles for that as well. What then shows is the pair of subtitles for tv show 1. and they show for tvshow 3-4-5-6 etc. they're "stuck"
I noticed that tv show 1 subtitles are in userdata - appdata and in the subscene folder. I deleted the subtitle file there. Then went back in and startet tvshow 2 or 3 or 4 or whatever, again, and downloaded a new pair of subtitles and once again tv show 1 subtitles came up and the file is back in the userdata - addon - subscene folder.
opensubtitles works perfectly as it should but i like subscene way better, much faster and more subtitles to chose from, so pls fix fast
If still needed i will produce a debug log.
Thanks for your work, i really appreciate it and sorry for any bad english, if any
2014-11-04, 16:00
Hi Pressi,
There was an issue in the past where temporary files weren't cleaned up afterwards and so some file seemed to be stuck. But I thought I fixed that issue. Could you please provide a debug log, so I can check the specifics of your issue.
2014-11-08, 15:02
The same problem that i had with my addons, check for solution:
http://forum.kodi.tv/showthread.php?tid=...pid1831823
2014-11-09, 14:32
Hi
i have some problems with this plugin, it stopped working a couple of days back.
running latest stable openelec
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc2 in position 4: ordinal not in range(128)
File "/storage/.xbmc/addons/service.subtitles.subscene/service.py", line 424, in <module>
subs = download(params["link"])
File "/storage/.xbmc/addons/service.subtitles.subscene/service.py", line 296, in download
shutil.rmtree(__temp__)
File "/home/stephan/projects/openelec-4.2/build.OpenELEC-Generic.x86_64-4.2.1/Python-2.7.3/.install_pkg/usr/lib/python2.7/shutil.py", line 239, in rmtree
File "/home/stephan/projects/openelec-4.2/build.OpenELEC-Generic.x86_64-4.2.1/Python-2.7.3/.install_pkg/usr/lib/python2.7/posixpath.py", line 71, in join
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 4: ordinal not in range(128)
2014-11-10, 23:03
(2014-11-04, 16:00)CrowleyAJ Wrote: [ -> ]Hi Pressi,
I have this issue aswell, the temp files in addon_data is not deleted. I tried uploading the log files using the kodi log uploader, but never got an email. Im using version 1.03 of subscene and Helix beta 2 (also tried with latest nightly build, but same error)
Because I havent received an email for the log link, heres what I think is causing it in the debug log:
21:14:43 T:3152 DEBUG: ### [__main__] - Saving subtitles to 'C:\Users\stue\AppData\Roaming\Kodi\userdata
\addon_data\service.subtitles.subscene\temp\subscene.xxx'
21:14:43 T:3152 DEBUG: ### [__main__] - Discovered ZIP Archive
21:14:43 T:3152 DEBUG: ### [__main__] - Failed to save subtitle to C:\Users\stue\AppData\Roaming\Kodi\userdata
\addon_data\service.subtitles.subscene\temp\subscene.zip
21:14:44 T:6028 DEBUG: CZipManager::GetZipList - Processing zip://C%3a%5cUsers%5cstue%5cAppData%5cRoaming%5cKodi
%5cuserdata%5caddon_data%5cservice.subtitles.subscene%5ctemp%5csubscene.zip/
21:14:44 T:6028 ERROR: XFILE::CDirectory::Create - Error creating C:\
21:14:44 T:3152 DEBUG: ### [__main__] - === returning subtitle file C:\Users\stue\AppData\Roaming\Kodi\userdata
\addon_data\service.subtitles.subscene\temp\Homeland.S04E05.HDTV.x264-KILLERS.srt
Alternatively I can send the log file some other way if need be.
2014-11-11, 22:41
My problem was related to the fact that Subscene apparently is offering ZIP files that OpenELEC's unzip (v6.00) command does not support. Maybe that's similar to what XBMC is experiencing ? The exact error can be seen on the command-line when trying to unzip the temporary file that was downloaded:
Unzipping the file on my RHEL6 Linux system (using unzip-6.0-1.el6) did not pose any problems:
So what _is_ weird is that both versions report the same exact version information, so either the RHEL6 version has been patched for this issue, or they were compiled differently, or there is an architecture-dependent issue involved.
Dag
xbmc01:~/.xbmc/userdata/addon_data/service.subtitles.subscene/temp # unzip subscene.zip
Archive: subscene.zip
skipping: SomeSubtitle.srt need PK compat. v4.5 (can do v2.1)
[dag@moria ~]$ unzip subscene.zip
inflating: SomeSubtitle.srt
Dag
2014-11-13, 21:12
There seems to be a problem with the temp directory not being deleted before the new subtitle is downloaded.
So the same archive is unpacked over and over and you get stuck with the first subtitle you downloaded via this service.
In order to fix this, just apply the changes of the pull request I made.
https://github.com/manacker/service.subt...ll/1/files
Now, it all works as i'ts supposed to.
2014-11-13, 22:25
Thanks for the pull request Philonimbus.
I submitted it to the official repo. I should appear as an auto update soon.
