Hey man ,,
I wanna a real help ..
suddenly subscene add-on stops .. every time I choose a Movie or TV show and choose the subtitle from subscene it say's :
Error
Script failed! : Subscene.com
I choose Arabic subtitle and I got that error message .. plz tell me what to do because not all the subtitle are available in
OpenSubtitle.org add-on .. and I need the
subscene add-on to work ...
waiting your reply as soon as possible ..
thanks a lot ..
by the way I am using XBMC Gotham 13.2
guys.. anyone who is expert in Subscene ?!!
plz help .. I'm still waiting ..
Hi guys
I have problem with Arabic subtitle
The subtitle come inPersian language in instead of Arabic
Help please
Hi CrowleyAJ
I followed the instruction from the link you sent me, so i opened Movie25 _ movies _latest Hd then i choose a randome movie ( in to the storm )_add arabic subtitle from open subtitle again the subtitle appear in Persian .
This is my debug xbmc.log:
http://xbmclogs.com/show.php?id=368506
Many thanks
Hi Mahdi75i,
thanks for your log. Unfortunately it doesn't contain any tries to find or download a subtitle. Can you upload a log from right after your problem occurred, please.
Recently I started getting "no subtitles found" for every TV episode I try to watch. Doing a manual search works fine though. Has anything changed on the Subscene website causing this? Maybe it's related to the fix made for plugging version 1.0.1? I'm running gotham 13.2 on atv2 using English subtitles.
Hi deenajs,
You are right, they changed something on the website. I just submitted a fix.
is there any one here ..
I'm still waiting for a solution for my problem
plz help ,,
i tried the steps and I put my email in the log uploader add-on but it doesn't send it to my email so I can send it to you ?!!
if you want to see what's going on with me in subscene subtitles just change the language that you want it as a subtitle to Arabic and then try to open any Movie or TV show and then choose subtitle from subscene .. then you will see the problem i am talking about ..
I just tried to download an arabic subtitle and it worked just fine for me. To see what went wrong for you, I need to look in your log.
You can send the log file to
[email protected]
