(2014-05-22, 01:04)Vonspiel Wrote: [ -> ]Colbert and The Daily Show Full episodes played perfectly. However, it seems that inside Amy Schumer Full episodes only contains clips and all of them gave me an error.
See the log: http://snipurl.com/28xp6tq
Website was changes again. Very small update and now they are working again (same URL as posted above for the updated version). However, before I made the change, even the clips in full episodes were working. From the logs it appears you had a time-out issue. This is usually not related to the script.
On top of Comedy Central shows, it seems there are some problem with The Tonight Show Starring Jimmy Fallon. I still have access to the clips but the full episodes give me back an error.
I know I must be doing something wrong, but I don't know what. Running XBMC 13.0. Tring to run USTV VOD add-on won't even open Lists "Script Failed: USTV VOD. Any help would be greatly appreciated.
can't seem to access the add-on. Any time I trt to open it it gives the same error.
"ScriptFailed! : USTV VoD."
Here is the log link
http://xbmclogs.com/show.php?id=209798
Any help would be wonderful, as I am hopelessly lost!
Thanks so very much!
@trankdm
I guess you don't install via repository. Am I right? Do it. Go to release thread and download repository/xbmcplus-plugins or right down in my signature. Reinstall.
It is just me or is ABC world news seem to always be showing a week behind?
For example the episode listing now goes up to the 16/5/2014
Yes because you need to sign in with cable provider details on the website to get the most recent episodes.
Are there actually any Full episodes of Amy Schumer on the website?
moneymaker
OK I uninstalled the one that wasn't working, and installed the repo, that you had linked. Now I don't get the Error when opening the add-on. It does open and shows me the listing for Favorite, All shows, and ABC only, no other network listings. And when I try to access ABC, that's when I get the error. I hate knowing that I am in way over my head...I know I'm making an the mistake I just don't know enough about ti to figure it out. Thanks for trying to help, and any other suggestions will be wonderful.
(2014-05-27, 02:20)trankdm Wrote: [ -> ]@moneymaker
Always post logs, so I can see whats going on behind. Looks like it's still something missing.
Any ETA regarding fixing The Tonight Show full episodes? My wife is asking me everyday to fix it and I'm like "I wish I can!" ha ha
EDIT: Noticed I didn't share my log regarding this issue. Here it is:
http://xbmclogs.com/show.php?id=212408 (Using the nbc.py on
github)
Fix checked in a couple of days ago
Well I've done everything but skin the cat and I still get this daaaagone script error UST VoD. I've installed from the repository, uninstalled and reinstalled, have the
repository.xbmcplus.xbmc-plugins-2.0 added on and still get the script error. Here is my log and any help would be very much appreciated. Oh yes I have the G-box 2.2 with the new Frodo Linux Build.
http://xbmclogs.com/show.php?id=215329
