2014-07-22, 03:18
2014-08-07, 14:20
Not sure if people are aware but stane83 has released a Linux build for s802 amlogic hardware
2014-08-07, 17:12
Netflix on minix will always be 480p 1750kbps max due to netflix not allowing HD on just any hardware. It needs to go thru a certain validation process for that. The minix representative on their forums has said that netflix has never bothered to repond to their request, so dont keep your hopes up.
2014-08-12, 17:10
I'm thinking of buying M8 MX Amlogic Android 4.4 Kitkat Quad Core 4k 5G Wifi TV Box XBMC Media Player. Wifi have a good signal? XBMC already installed that works well? Addons of movies and TV series in HD and SD works well? The picture and sound work well? Do not crash? I will use mainly for watching movies in xbmc. Advise the purchase of this box?
2014-08-12, 18:53
If you do make sure you get the beelink one... and also check out the amlinux for it as it makes this box fly
2014-08-25, 21:10
Since a few days I have the tronsmart s89-h. Most things look okay but for me 1 thing is crucial and that is that nextpvr's tv-recordings must be played back okay and that's where the box fails because these ts-files give lots of horizontal tearing on (strong) horizontal panning of the camera and the audio is a bit ahead.
Where should I post to get help on this? If this can't be fixed I want to return the box.
Wim
Wim
2014-08-30, 19:46
Hello
I have a box M8 MX Amlogic Android 4.4 Kitkat Quad Core 4 k 5 g Wifi TV Box XBMC Media Player and installed the latest version of xbmc, a nightly Kodi of 29 August. I can watch movies, but I have to have the amcodec off to see image. It turns out that some 720 p movies creep and I saw a forum to enable Libstagefright and so I can see all movies 720 p 1080 p movies, but the box restart. How can I fix this? Being a box amlogic shouldn't have the amcode enabled?
2014-08-30, 20:06
(2014-08-30, 19:46)marcovicen Wrote: [ -> ]Hello
see http://forum.xbmc.org/showthread.php?tid=195484 read to the end post.
2014-11-28, 01:55
Does anybody knows what are the main differencies between Amlogic MX III 2GB and Amlogic M8 2GB?
Which one is better?
Two sample links:
http://www.ebay.de/itm/MX3-MXIII-Amlogic...3ce1be9085
http://www.ebay.de/itm/M8-Amlogic-S802-Q...2ed8809281
Two sample links:
2016-01-14, 06:14
(2014-08-25, 21:10)WimKl Wrote: [ -> ]Since a few days I have the tronsmart s89-h. Most things look okay but for me 1 thing is crucial and that is that nextpvr's tv-recordings must be played back okay and that's where the box fails because these ts-files give lots of horizontal tearing on (strong) horizontal panning of the camera and the audio is a bit ahead.
Wim
Hey, saw your post as I'm looking for a S802 box to run mostly XBMC but I need nextPVR to be running well (recordings) as well as live TV via the HD Homerun app. I know this is an old post but it's the only one I could find to address this question that I also have.
Do the latest Kodi/SPMC versions run ok on the S802 (it's with the Mali 450 I think right)? Fell free to PM me.
