2014-04-19, 09:55
2014-04-20, 13:45
Brinis: Where did you order it from?
And what kind of filetypes have you tested it with?
2014-04-21, 00:06
I got it from geek. I have been using all the movies I can and the all play good. It's the 8gb I have but I have the 16gb on the way to now for my bedroom. I know it's only the wifi that is different on it. The one I have now I use on wifi
2014-04-21, 00:12
I get mine this week can't wait to test it.
2014-04-21, 22:35
Thanks for the info.
This sounds promising, love to see more tests. maybe with some vidz?
2014-04-21, 22:37
I'll do a video. Also check out some cool tech on YouTube he has a good review of this box.
2014-04-23, 22:01
Anyone have any ideas when they will release the Minix NEO X8s?
2014-04-23, 22:41
My rep told me mid go end of May they should have them in.
2014-04-24, 00:12
2014-04-24, 12:10
What about pricing (NEO X8s)?
2014-04-24, 18:00
Mi Box Pro from Xiaomi is another media player based on AMLogic S802 "Meson8" series SoC
http://www.cnx-software.com/2014/04/23/x...-s802-soc/
What makes this one a little special is it will cost less than $65 US-dollars (RRP ¥399 CNY)
http://www.mi.com/hezis
Quote:Mi Pro Box specifications:
SoC – Amlogic S802 quad core Cortex A9r4 processor @ 2GHz with ARM Mali-450MP6 octa-core GPU
System Memory – 2GB RAM
Storage – 4GB eMMC Flash + micro SD slot up to 64 GB
Video & Audio Output – HDMI (Up to 4K30) and 3.5 mm AV
Audio / Video Playback – MKV, AVI, MP3 and MOV up to 4K resolution. AC3, Dolby and DTS audio support
Connectivity – Dual band 802.11 b/g/n/ac Wi-Fi up to 120 Mbps (vs 40 Mbps for 802.11n)
USB – 1x USB 2.0 host port + 1x USB OTG port
2014-04-25, 12:32
Yes but what 802 chip will have inside? We need the one with hardware DD support
2014-04-25, 12:47
(2014-04-25, 12:32)bluechris Wrote: [ -> ]Yes but what 802 chip will have inside? We need the one with hardware DD supportNote that XBMC doesn't support h/w accelerated audio codecs, which are very much pointless with such powerful CPU's anyway...
2014-04-25, 17:33
Amlogic chipset overview, a few I didn't even know existed
S802 series is the one folks have already gotten their hands on.
S812 series is same CPU/GPU as S802 but adds 4K H.265/HEVC video decoding support and gigabit ethernet.
S805 series is a lower budget unit, Cortex A5 quad core CPU, still supports H.265 video but limited to 1080p output.
2014-04-28, 00:51
Why not just use pass through audio
I am assuming in line with the tronsmart and x7 x7 mini
(2014-04-24, 12:10)luksol Wrote: [ -> ]What about pricing (NEO X8s)?
