2014-06-01, 18:58
2014-06-01, 22:09
(2014-06-01, 18:58)diztorted Wrote: [ -> ]Seeing the same thing with version 0.0.2... reverted back to 0.0.1, and all is good again, though.. So, that's something!
I installed this addon in version 0.0.1 but it automatically updated to the new version 0.0.2. So in the next few hours/days your version will be updated too and the problem will appears again I think
2014-06-02, 11:08
(2014-06-01, 22:09)Eruurk Wrote: [ -> ]I installed this addon in version 0.0.1 but it automatically updated to the new version 0.0.2. So in the next few hours/days your version will be updated too and the problem will appears again I think
Indeed, that did happen.. So, I just took it a step further and disabled auto-updating of addons. That learned it!
2014-06-02, 11:18
So where are the log files then (using pastebin.com)?
No logs, no possible fix.
2014-06-02, 13:29
See below.
2014-06-02, 14:14
(2014-06-02, 11:18)Martijn Wrote: [ -> ]So where are the log files then (using pastebin.com)?
What like this one posted a few days ago?:
(2014-05-29, 09:35)shlowbro Wrote: [ -> ]Sorry to be a bother, but just did a clean install of v0.0.2 and configured everything but still got nothing
http://xbmclogs.com/show.php?id=213209
Here's mine:
http://pastebin.com/wm0iCtUq
I turned debugging on and played five mp3 files from my NAS. Paste expires in a week.
As a temporary solution I downloaded 0.0.1 and edited the version number in addon.xml to 0.0.3.
2014-06-02, 14:49
You will find my debug XBMC log here: http://pastebin.com/RivhyrAL
I hope this will help to resolve this issue. Thank you for your support.
2014-06-03, 02:20
Quote:As a temporary solution I downloaded 0.0.1 and edited the version number in addon.xml to 0.0.3.
Just did it too. Works fine now.
2014-06-03, 19:25
Version 0.0.2 not working for me. Linux, Gotham 13.1-beta2. I haven't tried the earlier version.
You can find debug-log here http://www.xbmclogs.com/show.php?id=216690. There's only one song being played, though.
EDIT: Tried 0.0.1 and scrobbling is working with that. Love-button with Metropolis-skin doesn't work but gives this error in the logs:
EDIT2: I tried this also with Spotlight, a Spotify add-on. Scrobbling doesn't work with tracks played from Spotify. I don't know if it should? It would be nice if it worked so each add-on wouldn't need to implement their own scrobbling.
20:30:30 T:139943302785344 ERROR: Keymapping error: no such action 'lastfm.love' defined
2014-06-05, 21:49
Same problems here, my log: http://www.xbmclogs.com/show.php?id=218302
2014-06-05, 23:46
Not working here: http://xbmclogs.com/show.php?id=218509
Don't see anything in the log about last.fm though
2014-06-06, 16:52
Another one reporting that v0.0.2 doesn't work. Nothing in the logs at all.
2014-06-06, 19:23
(2014-06-03, 02:20)shlowbro Wrote: [ -> ]This works great.Quote:As a temporary solution I downloaded 0.0.1 and edited the version number in addon.xml to 0.0.3.
(2014-06-06, 16:52)JoyrexJ9 Wrote: [ -> ]Another one reporting that v0.0.2 doesn't work. Nothing in the logs at all.And same here.
2014-06-06, 19:28
(2014-06-02, 14:14)VanZan Wrote: [ -> ]As a temporary solution I downloaded 0.0.1 and edited the version number in addon.xml to 0.0.3.
It's enough to change the version number to 0.0.2 to prevent auto-updating. That way you'll get the real 0.0.3 version automatically when it's released.
EDIT: VanZan commented later in the thread that if you keep the version number at 0.0.2 you have to delete the real 0.0.2 from packges (addons/packages/service.scrobbler.lastfm-0.0.2.zip) before installing the fake one from zip.
I think it also works if you change the fake 0.0.2 zip-package name to something else than the original, like service.scrobbler.lastfm-fake-0.0.2.zip. I think I did that and that is why I didn't notice this before.
2014-06-12, 18:48
Hm that didn't work for me. I uninstalled the real 0.0.2, downloaded 0.0.1 and renamed the version in addon.xml. But still no scrobbling. Did I miss something?
