2016-01-30, 08:48
(2016-01-30, 02:57)Warner306 Wrote: [ -> ]Remapping to these drives to SMB would be the ticket, if you wanted to go down that route.I will give it a try later today thanks!
(2015-11-22, 22:57)Warner306 Wrote: [ -> ](2015-11-22, 22:53)greatmanu80 Wrote: [ -> ]I need some help with setting rules in Dvdplayer merits. The itv player add on seems to be using dsplayer for streaming, which crashes. BBC iplayer streams using Dvdplayer so I don't know why itv is not. If I menu click on an itv stream and change the player to Dvdplayer it works great. But when just pressing play it uses dsplayer. I'm using the latest Isengard version of dsplayer. Can I set up a specific video add on to use Dvdplayer? What should I change in the the merits option.
Video Add-ons – Streaming Content
Playback of most http/https streams from video add-ons is possible with DSPlayer using LAV Splitter Source. The odd incompatibility may be encountered where add-on links are loaded instead by DVDPlayer. The use of DSPlayer for streaming sources does come with limitations. Currently, buffering issues, failure to load streams and slow navigation may be experienced with some add-ons. If you find playback or navigation is suffering, it is possible to substitute DVDPlayer as the video player.
The link below contains a copy of playercorefactory.xml, which contains instructions pre-configured to reroute Internet protocols (e.g. streaming content) to be played with DVDPlayer.
If your preference is to use DVDPlayer for video add-ons, move the included playercorefactory.xml from DVDPlayer merits to:
C:\Users\Username\AppData\Roaming\Kodi\userdata
DVDPlayer merits: https://drive.google.com/file/d/0B2LAr9I...sp=sharing
(2016-02-02, 14:21)dymas Wrote: [ -> ](2015-11-22, 22:57)Warner306 Wrote: [ -> ](2015-11-22, 22:53)greatmanu80 Wrote: [ -> ]I need some help with setting rules in Dvdplayer merits. The itv player add on seems to be using dsplayer for streaming, which crashes. BBC iplayer streams using Dvdplayer so I don't know why itv is not. If I menu click on an itv stream and change the player to Dvdplayer it works great. But when just pressing play it uses dsplayer. I'm using the latest Isengard version of dsplayer. Can I set up a specific video add on to use Dvdplayer? What should I change in the the merits option.
Somehow Live-TV via simple iptv is still played with dsplayer. I think it uses http-protocol though. No idea what's wrong. Other add-ons like YouTube use Dvdplayer with this preconfigured merits-rule.
(2016-02-04, 05:42)maddiesdad15 Wrote: [ -> ]My particular issue is AVC1 files not triggering the DSPlayer. I'm sure there's a simple fix....which I simply have failed to stumble upon. Any assistance would be much appreciated.
(2016-01-22, 21:39)huhn Wrote: [ -> ]"disable calibration" controls for this display doesn't have extra option. "this display is already calibrated" does have option so again i don't know what your calibration settings are i have no clue what setting you are using in the "this display is already calibrated".
so of cause they behaved different depend on what setting you are using in "this display is already calibrated" by default it looks or should looks the same as "disable calibration settings" because the default setting is bt 709.
(2016-02-04, 18:30)gotham_x Wrote: [ -> ](2016-01-22, 21:39)huhn Wrote: [ -> ]"disable calibration" controls for this display doesn't have extra option. "this display is already calibrated" does have option so again i don't know what your calibration settings are i have no clue what setting you are using in the "this display is already calibrated".
Huhn, excuse me, I lost the continuation of our discussion, I am sorry, too many threads to be controlled.
my current setting (Calibration) is "this display is Already calibrated" with default settings:
BT.709
Pure Power Curve 2:20
HDR for running and setting "disable calibration" NOT there would be no difference, with "this display is calibrated Already"? at least, that is what I understand
(2016-02-04, 05:58)Warner306 Wrote: [ -> ](2016-02-04, 05:42)maddiesdad15 Wrote: [ -> ]My particular issue is AVC1 files not triggering the DSPlayer. I'm sure there's a simple fix....which I simply have failed to stumble upon. Any assistance would be much appreciated.
I didn't address this in your PM.
You could try setting your filters to Media rules and Filters configuration and adding that file type to this list already provided.
These are my starter files.
You have to place them in the userdata -> dsplayer folder.
This will require you install external copies of LAV Filters and XySubFilter. Links are found at the end of section 3.
It could be aracnoz simply forgot to include this file type.
(2016-02-05, 05:34)maddiesdad15 Wrote: [ -> ]Added the starter files and downloaded the external filters, but DSPLayer will not activate with MediaRules/FilerConfig selected. Plays fine with Internal Filters and DirectShow merits
Debug.log
The assistance is very much appreciated.
(2016-02-05, 22:30)Warner306 Wrote: [ -> ](2016-02-05, 05:34)maddiesdad15 Wrote: [ -> ]Added the starter files and downloaded the external filters, but DSPLayer will not activate with MediaRules/FilerConfig selected. Plays fine with Internal Filters and DirectShow merits
Debug.log
(2016-02-04, 05:58)Warner306 Wrote: [ -> ]I didn't address this in your PM.
Did you check your Media rules to make certain the dsplayer files are installed? You should see a rule in there somewhere.
I'm not good at reading logs, but it looks like things failed at LAV Filters. You need LAV 32-bit.
Also, the file :The.Lost.Capone.1990.m3u8 has a file extension not included in the list of media rules.
I would suggest setting up a playercorefactory.xml for MPC-HC and playing your VC1 files with MPC-HC. You would still get the use of madVR. There is an entire guide dedicated to getting this working. I suspect you'll never get those files to work.
