2017-08-20, 02:56
2017-08-20, 03:20
(2017-08-20, 02:56)Chrolm Wrote: [ -> ]Any hidden options to load a profile from the network? -profile \\machine\... doesn't work.Nope, only folders inside the "Profiles" directory will be loaded.
Gesendet von meinem VTR-L09 mit Tapatalk
2017-09-08, 21:52
What would be cool is a command line option to update watched state from Kodi - one for TV and one for Movies.
Edit: For my use (at least) just scanning unwatched Movies/TV episodes would be plenty. Should cut down on the job.
2017-10-09, 14:04
Back having issues !
I have managed to setup everything , commandline script works, ember loads up, BUT DOES NOTHING... No Scraping of anything Tv Show or Movie??
Here's my Commandline structure
"C:\Emm\emm.exe" -updatetvshows -updatemovies -newauto -all -nowindow
What am I Doing wrong ?
Please Help
Please Help
2017-10-09, 14:45
(2017-10-09, 14:04)shaktoo Wrote: [ -> ]Back having issues !With version of Ember do you use?
Please Help
2017-10-09, 14:45
Please Help
Try "C:\Emm\emm.exe" -updatetvshows -updatemovies -scrapemovies newauto all -nowindow
That won't scape new TV Shows it will only scrape new episodes for already scraped TV Shows.
2017-10-10, 20:44
Are there any commands to scrape movie sets?
2017-10-10, 23:04
(2017-10-10, 20:44)Fail$tyle420 Wrote: [ -> ]Are there any commands to scrape movie sets?
Yes, should be working with:
-scrapemoviesets [ScrapeType] [ScrapeModifier] {additional ScrapeModifier}
I've added the information to the first post :-)
EDIT: Just recognized that the command "newauto" and "newskip" are broken for -scrapemoviesets. Both are linked to "scrape movie" instead of moviesets. Has been fixed for next version: Github
2017-10-10, 23:28
(2017-10-10, 23:04)DanCooper Wrote: [ -> ](2017-10-10, 20:44)Fail$tyle420 Wrote: [ -> ]Are there any commands to scrape movie sets?
Code:-scrapemoviesets [ScrapeType] [ScrapeModifier] {additional ScrapeModifier}
Awesome! Thank you soooooo much!
2017-10-16, 17:00
I have done a fresh install and ember is working fineon its own. Just the command Line even with all the correct way I am still not able to get it going. Ember Loads up but does not scrape anything ??
"C:\Ember Media Manager BETA\Ember Media Manager.exe" -updatetvshows -updatemovies -scrapemovies newauto all -nowindow
TIMEOUT / T 120
taskkill /IM Ember Media Manager.exe /F
Also the time out / task kill arent working either ?
TIMEOUT / T 120
2017-10-16, 19:08
(2017-10-16, 17:00)shaktoo Wrote: [ -> ]I have done a fresh install and ember is working fineon its own. Just the command Line even with all the correct way I am still not able to get it going. Ember Loads up but does not scrape anything ??
TIMEOUT / T 120
So I'm assuming that this is in a batch file? Your timeout script needs to remove the space after the / and before the T. Taskkill I usually put /F before /IM, but I would think that your syntax should work correctly. Now, if those 2 commands aren't working, that has nothing to do with ember and has EVERYTHING to do with windows. That might explain why your ember isn't doing anything. Also, no reason for a timeout or taskkill, as once ember is done running your code, it SHOULD exit on it's own.
2017-10-17, 16:05
(2017-10-16, 19:08)Fail$tyle420 Wrote: [ -> ](2017-10-16, 17:00)shaktoo Wrote: [ -> ]I have done a fresh install and ember is working fineon its own. Just the command Line even with all the correct way I am still not able to get it going. Ember Loads up but does not scrape anything ??
TIMEOUT / T 120
You Know what ... I stand corrected, the batch command line scraping is working.. with my current config .. it IS working and everything's Back to normal again.
thanks Failstyle & Dan & all for your kind suggestions
2017-10-18, 01:11
Glad you got it sorted out!
2017-11-09, 06:42
So I finally got around to trying this. I simple used this command:
It runs, I can see my new TV shows when I open Ember..but nothing scraped... have I done something incorrect? Thanks in advance
"S:\Ember Media Manager BETA\Ember Media Manager.exe" -updatetvshows -updatemovies -scrapemovies -scrapetvshows newauto all -nowindow
2017-11-09, 10:30
(2017-11-09, 06:42)NewYears1978 Wrote: [ -> ]So I finally got around to trying this. I simple used this command:
Code:"S:\Ember Media Manager BETA\Ember Media Manager.exe" -updatetvshows -updatemovies -scrapemovies -scrapetvshows newauto all -nowindow
Yes. Each database update reset all "new" movies/moviesets/tv shows/epsiodes to "not new". That means if you want to update tv shows and movies, also scrape tv shows and movies you have to change the ordering to:
- update tv shows
- scrape new tv shows
- update movies
- scrape new movies
The solution for you is:
"S:\Ember Media Manager BETA\Ember Media Manager.exe" -updatetvshows -scrapetvshows newauto all -updatemovies -scrapemovies newauto all -nowindow
