2007-01-10, 03:30
2007-01-10, 03:45
kraqh3d Wrote:the true screensaver, no. but you may be able to approximate it with an animated gif.
anyone know where I can get an animated Matrix GIF?
2007-01-10, 05:24
XBMC-SVN_2007-01-09_rev7554-T3CH is out.
2007-01-10, 07:24
I am having an issue with the IMDB function under this skin. I am unable to select the movie thats returned at the top of the list when the IMDB query returns the list of possible movies. I can scroll down and select any other entry, but not the first one. Even if it only returns one entry..
Anybody else having this problem?
2007-01-10, 07:51
I think i have found a little problem in the Weather settings- I can pull up the weather settings, and try to change the area code ,I can get it to display my local info but I cant save it. I have tried all three city's with the same result. I am using svn 231. I really like the skin .
2007-01-10, 08:09
scottapalmer Wrote:I think i have found a little problem in the Weather settings- I can pull up the weather settings, and try to change the area code ,I can get it to display my local info but I cant save it. I have tried all three city's with the same result. I am using svn 231. I really like the skin .
Thats basicaly the same problem I have with the IMDB query results.. I just noticed the same problem in the weather section as well.. You can click the first entry..
2007-01-10, 08:13
Hmm, can't seem to find how to edit your own message.. anyway.. I meant to say... You CAN'T click the first item..
2007-01-10, 08:16
Two things I came to think of, but I guess the first one is rather a part of XBMC than the skin. Is it possible to shut off the music visuals on the main page, and only have it on the full screen visuals screen?
Also, the big "Now playing" thing on the full screen visuals was great. But it looks kind of wierd when you also have the small standard "Now playing" info at the bottom of the screen. And it would be great to have that big Now playing info at the home page, since there's a already a big empty space in the middle of the screen, perfect for such things. And that it didn't dissapear as soon as you move anything on the controller.
2007-01-10, 08:31
wreezig Wrote:Two things I came to think of, but I guess the first one is rather a part of XBMC than the skin. Is it possible to shut off the music visuals on the main page, and only have it on the full screen visuals screen?1. You can disable the background visualization in the Skin Settings on the home screen.
2. I was thinking the exact same thing. The middle just seems so empty; "now playing" info would go well there. Since this skin is still in beta, I'm going to guess that something of the like is on the drawing board, but hasn't been done yet.
2007-01-10, 08:39
edwinmcdunlap Wrote:1. You can disable the background visualization in the Skin Settings on the home screen.
Hm, how? I must be blind. :p
But actually, that question was a bit general, referring to all skins, specially in the MC360 skin.
2007-01-10, 08:49
Msan Wrote:Thats basicaly the same problem I have with the IMDB query results.. I just noticed the same problem in the weather section as well.. You can't click the first entry..
Well, this seems to be an XBMC issue an not the skin, this even happens with PMIII
2007-01-10, 11:16
It's fixed in SVN.
2007-01-10, 14:53
u can make a matrix gif in gimp
2007-01-10, 15:26
Matrix trails on the net....
http://www.bu.edu/av/photonics/OLD/matrix.gif
not exactly high res.. but sure you can find better/make better...
2007-01-10, 19:54
Here's a Photoshop tutorial where you make your own animated Matrix background... http://www.newtutorials.com/matrix-backg...torial.htm
