(2016-03-21, 14:25)sabofer Wrote: [ -> ]Hi Tomer
Just tried updating the folder with the Zip content.
are the menue screen suppose to be that big?
They cover the Entire screen.
PLUS - there is a problem with Exodus (and maybe other addons):
when i choose a movie - i don't see a list of sources .. instead i see a list that contain only the name of the movie..
screenshots of both issues will be helpful..
(2016-03-21, 17:49)sabofer Wrote: [ -> ] (2016-03-21, 16:46)tomer953 Wrote: [ -> ] (2016-03-21, 14:25)sabofer Wrote: [ -> ]Hi Tomer
here you go
http://imgur.com/a/n4FZH
both issues are fixed. please test...
and yes, the new progress dialog should be in full width (I think it's pretty nice..) - but I upgraded it a little bit.. check again.
LOVE THE SKIN!!! Finally a Showcase View with rolling diskart and working Movieset Disks that's solid as a rock. I was using Madnox for a while now, but it's got too many bugs. Spent more time problem solving than enjoying my library.
I have only one request. Can you give us the option to hide The Icons on the home screen. I'm not a fan of Icons. I think they're unnecessary and crowd the look of this elegant skin. Thanks for your hard work! Cheers!
Hey, I love your skin. I am would like to see the following -
1. A home icon at the top so as to come to the home screen from any screen.
2. Change theme colors.
Ashsmh
(2016-03-20, 14:24)tomer953 Wrote: [ -> ] (2016-03-20, 13:01)shocker00 Wrote: [ -> ]Nice Work! Just a quick question, does this skin support TV Tunes and CinemaVision?
TV Tunes - yes.
CinemaVision - No, but I can look into it if it's important to you guys..
I would appreciate it if you don't mind. I been trying this skin out for the last couple days and I think its now become my favorite. Just need cinemavision for my home theater room.
(2016-03-21, 23:24)ashsmh Wrote: [ -> ]Hey, I love your skin. I am would like to see the following -
Ashsmh
1. for touch devices? in keyboard you can just hit ESC, and it remote you can define a button that do that.
2. you can already do this. Settings - Phenomenal - Design - the first option there...
I think right side bar taking a lot of spaces on main screen. Is there any way to setup main screen this way? I like the main screen clean. Thank you keep the good work!!
.png)
On my OpenElec install on a rPI2 the date doesnt fit into the top of the right side bar as shown in the screenshot above.
i get 22/03/20..
Anything i can do to make the bar a bit wider?
Great skin though, my new default
(2016-03-22, 14:50)el_easy21 Wrote: [ -> ]I think right side bar taking a lot of spaces on main screen. Is there any way to setup main screen this way? I like the main screen clean. Thank you keep the good work!!
.png)
there is an option for "use horizontal" navigation bar on one of the front pages under Appearance > Settings
(2016-03-22, 09:36)tomer953 Wrote: [ -> ] (2016-03-21, 23:24)ashsmh Wrote: [ -> ]Hey, I love your skin. I am would like to see the following -
Ashsmh
Thanks....But I did not understand the 2nd part of your answer to my question #1. I am using this skin on my Android Box RK3188.
(2016-03-25, 00:32)ashsmh Wrote: [ -> ] (2016-03-22, 09:36)tomer953 Wrote: [ -> ] (2016-03-21, 23:24)ashsmh Wrote: [ -> ]Hey, I love your skin. I am would like to see the following -
Ashsmh
I mean that Kodi supports custom buttons, that means you can define any command for any button, for example: the red button will launch "latest movies" etc...
but I guess that the remote you have is very simple remote, with only the basic buttons. so in that case you will have to do hit "back" few times in a row,
or just upgrade to a small htpc keyboard\better remote control.
anyway, even If I will add a home icon in all the screen, it will be for touch devices, so you can press on it, but you can't navigate to the button via the arrows only, because if ill do so it will break a lot of the functionally right now.
(2016-03-22, 06:48)shocker00 Wrote: [ -> ] (2016-03-20, 14:24)tomer953 Wrote: [ -> ] (2016-03-20, 13:01)shocker00 Wrote: [ -> ]Nice Work! Just a quick question, does this skin support TV Tunes and CinemaVision?
TV Tunes - yes.
can you test latest git ?
I added a button in the movie information dialog.
(2016-03-22, 15:02)DoubleT Wrote: [ -> ]On my OpenElec install on a rPI2 the date doesnt fit into the top of the right side bar as shown in the screenshot above.
i get 22/03/20..
Any one else seeing this issue?
