mm,
try to edit 1080p\font.xml
<font>
<name>menu-30</name>
<filename>NE.ttf</filename>
<size>30</size>
</font>
<font>
<name>menu</name>
<size>38</size>
</font>
I'm using NE font for menu items, you can replace it to arial.ttf or to your custom font (just include it in the skin fonts dir)
I have russian users who made the same, and duplicated the default fontset to a new one called "Russian", you can try to use it first before you modify the file..
I was wondering how can I change the background on main page? I wanted to use my own something darker for sure.
Actually you can always check in the skin github to check if I added some new stuff...
Today I'm working on a new "Pictures View", which includes clearlogo for the Camera model, and some cool EXIF icons:
Version 1.6.0
is now availble on abeksis repo:
http://abeksis.com/repo/repository.abeks...beksis.zip
or in github:
https://github.com/tomer953/skin.phenomenal
Changes:
- Remake of Vertical menu!
- Brand new view for your pictures library - including a clearlogo of the camera brand, and all the EXIF info (see img below)
- Option to set background for menu item from a widget content, this will give you rotating fanarts from the widgets, and when you will open the widget - you will see the movie that currently showing in the fanart.. and be able to play it.
- Added the aired date for episodes in widgets.
- PVR Channels is now supporting all the skin views.
Hm, web page changed to say it's on the Kodi repo but it's still not there... I guess we'll wait some more, this looks great even if I don't care about RTL
(2016-02-03, 20:15)krakout Wrote: [ -> ]Hm, web page changed to say it's on the Kodi repo but it's still not there... I guess we'll wait some more, this looks great even if I don't care about RTL
It's there as long as your on kodi isengard (15.2) ! The skin still doesn't support kodi 16.
Soon enough there will be a 16 version
Ahhh thanks for pointing that out mate! Indeed I'm on 16, gotta wait some (more) then!
Thanks again
I will try to post Jarvis version before the official release, hopefully in the next few days.
A skin that lives up to its name !!
Very nice work indeed.
