WeirdH Wrote:Perhaps I stumbled upon something buggy:
http://forum.xbmc.org/showthread.php?p=1...post138018
Also, with revision T3CH-9273, changing from Vision to PM3 hangs XBMC (still in Vision). I have to manually turn off the Xbox. When I turn it on again, the skin has been changed to PM3.
I also noticed this happens sometimes when changing from XTV to PM3.
Hey great news 9T9..I personally would like to see a Vista version, only because I like Glossy things!!
I think either would look great, but I reckon a Vista version would look nicer and cleaner.
Thanks for the update though mate...I will def try this when I get home tonight.
Nice, but uh.. I downloaded the latest build of T3CHs XBMC (17-06-07) and got a clean installation of this build of your skin, but now there's no visible text or clock in the middle. No matter what menu I choose there's no visible text.
Something that doesn't click with XBMC, or some bug in the skin?
Hm, seems to be an issue with T3CHs build, more skins fuck up, and I can't start any files.
Going for GasGivers latest build instead and will then test this new Vision.
Cheers.
WOW! pv3 looks fab. will report bak if ne bugs r found
ps i would also like to see a VISTA theme to be made next..
I would love to check out this icon pack, got a link somewhere? Cheers.
PS: Fabulous work!!!
Thank you guys! Wreezig, I had someone at XS with your problem, but he managed to get it fixed? so i dunno what to tell ya
Rand Al Thor, Keep a lookout for the link to the Icon Pack, im setting up the svn within the next couple days
wreezig i had the same problem as you, i then realised i was using a old build,
got the latest svn build and the text appeared, but now there is a new problem
i cant get the pm3 theme to work the skin is telling me i only have one theme to select from and yet the pm3.xpr is present in the correct 'media' folder.
the skin colours are working just not the new theme
Help?
Hm, got it to work now.
The new theme looks good, but I still prefer the old theme for Vision.
Noticed one bug in the new theme though, when choosing in dialouges you didn't see the marker. For example when you set the weather for a certain city and you get to choose from some different choises you can't see wich one you have marked at the moment.
wreezig Wrote:Hm, got it to work now.
Same, prefered original Vision !
i can't download the damn file >:@!
i will love to see Vista skin please
did you guys ftp the skin over or transferred it via a usb stick
still doesnt seem to be working for me, and im 110% sure that all the files are in the right places.
hXr.eXe Wrote:did you guys ftp the skin over or transferred it via a usb stick still doesnt seem to be working for me, and im 110% sure that all the files are in the right places.
download the file and ftp to the XBMC folder
XBMC→skins
just leave the folder like PM3→userdata, scripts, log.txt,default.xbe
not in this way PM3version1→PM3→userdata, scripts, log.txt,default.xbe
Can someone explain to me what is wrong with the Vision skin? I updated my XBMC to the latest, and I downloaded Vision skin and added it to the skin folder.
It seems some functions are missing from the Vision skin. For an example, in the PM3 skin, I can view files in, List, List2, Icons, Big Icons.
But in Vision skin I can only view the files in, List, Icons and Big Icons
When I go to Programs, Games, Videos, Pictures, Music etc. It doesn't show all expected files such as: Share, SMB share, Play DvD etc.
Just blank:/
Isn't Vision compatible with the new XBMC?
ive finally got pv3 working woot!! for some reason vision doesnt seem to be picking up the 2nd theme in the media folder only the default theme, so what i did was delete the orignal theme and renamed the pm3 theme to texures.xpr, the skin is picking it up now should have tried this earlier on..and wow!! pv3 looks awesome!! i also agree that the skin need to look a little darker...give me a couple of days to mess around wiv it and ill post what i like and dislike about the theme, only problem now is everytime i want to revert back to the default theme i have to delete copy rename...i hope its just a problem wiv this build..and its not at my end.
