(2017-02-24, 11:39)ronie Wrote: [ -> ]you can copy the 'skin.estouchy' folder to .kodi/addons
Ok, Thank you Ronie, my tuning is almost finished ...with your help !
(2017-02-24, 22:46)Tarkus_ Wrote: [ -> ]How do you get the weather to display at the top, as in the first screenshot?
screenshots are a bit outdated, there no longer is a weather icon at the top.
(2017-02-24, 23:00)ronie Wrote: [ -> ] (2017-02-24, 22:46)Tarkus_ Wrote: [ -> ]How do you get the weather to display at the top, as in the first screenshot?
That's too bad. Is there any hope of it making a return? I really missing having that (from using other skins).
Hi Ronnie - the Estouchy skin looks really GREAT.
I'm just having some troubles getting it fully working.
>> see my signature file for system configuration <<
I can't get the Touchscreen to work on all icons.
I've made a .MOV video if that helps you.
https://drive.google.com/open?id=0B190Kj...GhVZHBWY1E
The mouse and keyboard ARE connected - the RPi functions the same way withouth them.
On Settings > System > Input > I DO have the Enable Mouse & Touchscreen support ON.
The touchscreen only minimally works on the Estuary and Confluence skin too.
With the NOOBS I only installed LibreELEC, not Raspian ... if that means anything.
Thanks ...
Jim
I recently acquired a Nexus 7. I have Kodi playing media from my server.
Any way to remove the home screen widget, recently added, and just have either a fixed image or changing images from my fan art?
Thanks in advance,
Can you please make the favourites list the same size as in Estuary?
Actually the list entries are too small for a 7" screen.
The size is much better in Estuary
Thx
