Full Version: Aeon MQ 7 - Jarvis
AEON MQ 7 by MarcosQui - Kodi Jarvis - Public Release - 08/19/2016
Well, finally reached the public version of the skin. Heartfelt thanks to all who follow our work and helped in any way to make this skin a reality.
The download link it is at the end of this post.
Soon the skin will go to the official repository.
A SKIN IN 1080P - ALL CODE WAS ALTERED AND SOME TEXTURES WERE REDONE:
A NEW CONCEPT TO THE MAIN MENU - CLEAN AND MODERN VISUAL:
VERTICAL MENU - A SMALL AND CLEAN VERTICAL MENU THAT INTERFERES AS MINIMUM AS POSSIBLE ON THE EXISTING LAYOUT:
A NEW THEME - COLORS THAT MIX WHITE, YELLOW, ORANGE AND BLACK, DIFFERENT FROM ALL ALREADY EXISTENT:
A NEW CONCEPT TO WIDGETS - IT IS NEARLY A TYPE OF VISUAL DIRECTLY AT MAIN MENU:
A MORE AGILE MAIN MENU - THE WIDGETS SELECTOR HAS BECAME A POPUP WINDOW, KEEPING ITS FUNCIONALITIES. THIS SHOULD AVOID ITS UNNECESSARY LOADING.
SINCE THE FIRST USE IT IS EASY TO NOTICE THE BETTER PERFORMANCE:
A NEW COLOR FOR TEXTURES CALLED BY 'TERRACOTTA' CREATED ESPECIALLY FOR AEON MQ 7:
...and much more... a very large post to display everything would be needed. Wink
Download Skin Aeon MQ 7 - Jarvis
Ps. Install only skin.aeonmq7-1.4.0.zip.
resource.images.mediaicons.coloured-0.0.7.zip (coloured flags) and metadata.themusicvideodb.org-3.9.0.zip are optional.
More info: www.xbmcbrasil.net
Others Images:
reserved...
Simply the best skin for Kodi
Thanks again Marcos for the best skin ever Big Grin
A M A Z I N G!!!
The best skin of all times ; no doubt for me.
Really nice skin, thanks!
Let the modding begin!
I am proud to be among the participants in the language translation for this amazing skin.
Thank you Marcos for this great skin is really beautifull !!!
I have juste on question it is possible to change orange line to other color ( exemple for blue?) ? I dont have view in settings this option (i say orange line in main menu theme).
Again thank you for your hard works !
@Deki, yes, go to settings, skin settings, main menu area, option - Change the menu bar color (press enter).
Nice work @MarcosQui
Is there version for Kodi Krypton?
(2016-08-21, 01:33)movie78 Wrote: [ -> ]Nice work @MarcosQui
The most demanding user on this forum!
@Wanilton how do you turn off animated posters....
(2016-08-21, 01:55)Firetv344 Wrote: [ -> ]@Wanilton how do you turn off animated posters....
@ top menu on whichever view you are using...
So easy to figure...
