2021-06-12, 03:09
2021-06-12, 21:51
2021-07-13, 03:04
Is there a way to change the default view for the favorites on the main menu so they show as a list instead of icons?
2021-07-13, 06:23
(2021-07-13, 03:04)ezdropper Wrote: [ -> ]Is there a way to change the default view for the favorites on the main menu so they show as a list instead of icons?
Not without changing the code in the skin.
2021-08-08, 13:03
popy
please tell me, which lines in VideoOSD.xml need to be changed, so that the progress bar goes down under the play_pause buttons and others?
https://kodi.wiki/images/5/5d/Video_Playback_OSD_01.jpg
Is there a way to directly call the "Settings" menu (Gear icon)?
Like this
Sorry for my Google Translate english.
Like this
xbmc.executebuiltin('ActivateWindow(osdaudiosettings)'):xbmc.executebuiltin('ActivateWindow(osdaudiosettings)')
2021-08-08, 13:49
(2021-08-08, 13:03)A55555 Wrote: [ -> ]popyThere are 4 lines like this:
<control type="slider">
<top>105</top>
If I remember correctly changing the value to 105 moves it down.
2021-08-08, 13:51
<top>105</top>
If I remember correctly changing all of the value to 105 moves it down.
2021-08-08, 22:23
(2021-08-08, 22:09)A55555 Wrote: [ -> ]linknetThen you just need to do a side by side comparison with the original file to find it.
not really
Only slider went down.
Could be the last value here:
<control type="group">
<bottom>0</bottom>
<height>190</height>
<visible>![Window.IsVisible(SliderDialog) | Window.IsVisible(osdaudiosettings) | Window.IsVisible(osdvideosettings) | Window.IsVisible(VideoBookmarks) | Window.IsVisible(playerprocessinfo) | Window.IsVisible(osdcmssettings) | Window.IsVisible(PVROSDChannels) | Window.IsVisible(pvrchannelguide)]</visible>
<animation effect="fade" time="200">VisibleChange</animation>
<control type="label">
<right>20</right>
<top>35</top>
2021-08-10, 06:07
linknet
thanks.
I try, but so far the strip does not react.
thanks.
2021-08-10, 10:49
(2021-08-10, 06:07)A55555 Wrote: [ -> ]linknet
thanks.
I think you're in the wrong file, you need to look in this file:
DialogSeekBar.xml
<include content="PVRProgress">
Where the included content "PVRProgress" is in this file:
Includes_PVR.xml
<include name="PVRProgress">
It's not as straightforward as just changing a single value.
2021-08-28, 13:45
@linknet & @A55555
I have ported the option "added option to have seekbar at botttom of screen" over from this github: https://github.com/pkscout/skin.estuary....264250f5fc
Here is the new version 3.0.6 of the skin: https://drive.google.com/file/d/1cBXg-ES...sp=sharing
Just update and enable the option "added option to have seekbar at botttom of screen" to get the seekbar to the bottom.
2021-08-28, 21:43
popy
thanks for your help.
The option has appeared.
But it doesn't work for me
