(2017-04-07, 09:33)nickr Wrote: [ -> ]@kimkl if you keep posting nonsensical rubbish it will go to the bin.
I am not sure what you mean about rubbish, i was trying to explain that on most of the new webside say downloads, about, software, and so on you have links in the text "lets say get involved" but just below the big blue button also says get involved so i was just saying that it seemed a bit much to use the same links both in text and then blue button, and then i said that on most webpages you have the same info like downloads you have get involved you have donation and so on this is the same for the others pages but since you have dedicated donate and get involved pages is it necessary to mention these things on every other page.
But i see my attempt to be helpful is totally wasted, because no matter what i do or say, forget it your house your rules,
But it just feels annoying, like when i was the one that found out a month after 17 beta was released and there was a problem with the installing that you could just make the temp folder by yourself, did i get credit or a pat on the back nope "was not looking for it" but then in the later release it was written that you could just make the temp folder yourself.
My prob with that is it was written as if it was discovered by the "TK", okay i can live with that.
But when i now try and help out again, English is not my native language it says so in my tagline so it was hard to explain that you had the same info on all pages, even though you also had dedicated once, and instead of asking my meaning i get rubbish.
Yes i can see its hard to reads my meaning, but i was trying to help.
But seems the page you have on the new UI is just "smoke" the one saying how to get involved by helping out in forum.
If you go back some pages you will see i was right about some stuff and how to fix it like changing
http://kodi.tv to
https://kodi.tv and voila link works.
Do i sound mad yea a bit, i am trying to help out keep the off topic to a "REAL minimum" but seems i can't get a break.
Okay less mad now, and i do not care about getting credit every time my "fixes" turn out to be right, but i needed something to show you that yes i clown around a lot but i also try to help out.
This is not just pointing fingers at you nickr your a descent fellow but you were just in line of fire.
ill keep the rubbish to a minimum
Thank you
