2017-09-18, 18:58
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
2017-09-18, 19:54
Works fine!
Thank you!
Chris
Thank you!
Chris
2017-09-18, 20:32
Another question: If i want to change the function of the Radio button to start e.g. a radio addon.
Where do i have to add the ActivateWindows command?
Same question for Navigation.
I would like to use those two for other targets because i use the skin as gui for a mediacenter at home and not in a car.
Chris
I think i found the file. It should be in the includes.xml.
But i am not shure where exactly.
Chris
2017-09-19, 04:07
if i copy the favorites and put it on the other side and make it into a youtube button is this the way id do it in the picture below
https://imagizer.imageshack.us/v2/1135x6...u3xw6Z.jpg
2017-09-19, 09:36
(2017-09-18, 20:32)techie67 Wrote: [ -> ]Another question: If i want to change the function of the Radio button to start e.g. a radio addon.
Chris
If you want to use Radio addon i can add this for radio button(i will add anyway).
But if you want to change button totally this 2 buttons is in Includes.xml
line 375 for radio and 151 for navigation.
2017-09-19, 09:39
(2017-09-19, 04:07)1milenia Wrote: [ -> ]if i copy the favorites and put it on the other side and make it into a youtube button is this the way id do it in the picture below
That button is for right side list buttons.
If you want to add in left side than copy and edit fullscreen button.
2017-09-19, 22:10
Many thanks.
I will try it asap.
Chris
I will try it asap.
Chris
2017-09-19, 23:31
do you have a pic of what you neen full screen button
2017-09-20, 07:33
Here is the code for the button:
Modify for your need.
<control type="group" id="4272">
<posx>220</posx>
<posy>105r</posy>
<control type="button" id="4273">
<description>Fullscreen</description>
<posx>0</posx>
<posy>0</posy>
<width>100</width>
<height>100</height>
<texturenofocus border="6"></texturenofocus>
<texturefocus >list_focus.png</texturefocus>
<onclick condition="Player.HasAudio">ActivateWindow(Visualisation)</onclick>
<onclick condition="Player.HasVideo">ActivateWindow(FullscreenVideo)</onclick>
</control>
<control type="image">
<posx>100</posx>
<posy>15</posy>
<width>2</width>
<height>80</height>
<texture border="2">separator.png</texture>
<colordiffuse>blue</colordiffuse>
</control>
<posx>5</posx>
<posy>15</posy>
<width>90</width>
<height>80</height>
<texture>fullscreen.png</texture>
<bordersize>12</bordersize>
</control>
</control>
2017-09-21, 03:46
theres 2 onclicks witch do i use for youtube
2017-09-21, 05:58
Delete both.
and i suppose for youtube will be:
<onclick>RunAddon(plugin.video.youtube)</onclick>
2017-09-22, 01:53
thanks to add the icon whats the next step
2017-09-24, 21:01
(2017-09-03, 08:11)idorel77 Wrote: [ -> ]@zalamar,
you must have the apk or addon installed. That is just a shortcut button.
By enter the value you can change the onclick button , you can use the navigation button to open waze, maps or navit (i can add more actions if you use other navigation).
Same for radio.
@malin,
i will try.
First I want to congratulate you. This is exactly the kind of theme I was looking for my pc-car.
I am now trying to set it up to fill my needs but I don't understand how to customize Navigation and Radio buttons. I have Odroid C2 with Android system installed.
When I go to customize the Navigation button and enter for example 'Waze' I don't have any Validation button in the on-screen keyboard.
How do I save the value I enter ?
2017-09-25, 05:53
Yes , with enter key.
2017-09-25, 17:38
(2017-09-25, 05:53)idorel77 Wrote: [ -> ]Hi,
Thanks idorel77.
I see what is the problem. On my VU5 screen I don't see the buttons at the top right. I have installed kodi on a computer to test.
Do you see any solution to see those buttons on my VU5 screen ? I use a bluettoth remote with keyboard but the Enter key doesn't work on that screen.
